John Mueller Guest
Posted: Sun Oct 14, 2001 5:20 am Post subject: |
Help... I have replaced my ignition(MSD), and Distributor(Bosch). So now my problem seems to be that my engine keeps flooding and fouling the plugs. What am I missing??? The injectors have a good spray pattern and the fuel pump is brand new(Bosch). When I pull the plugs they are totally wet. Any ideas????
Thanks!
924martinirossi Guest
Posted: Sun Oct 14, 2001 6:11 am Post subject: |
Could be that the injectors are not shutting off after fuel delivery cut off.
Is the correct fuel pump relay installed?
924 77-78 477.906.059
924 79-82 433.906.059
924T 80-82 931.615.113.00
944 83-85/1 944.615.277.00
924S 87-88 944.615.227.00
Michael
Joes924 Guest
Posted: Mon Oct 15, 2001 12:41 pm Post subject: |
What does it do when started reaction/??
before fouling occurs
Posted: Mon Oct 15, 2001 12:56 pm Post subject: |
| perhaps the fuel pressure relief valve is jammed and you've got too much pressure at the injectors. That new pump will be giving a lot more pressure than the valve has seen in a very long time. |
John Mueller Guest
Posted: Tue Oct 16, 2001 3:40 am Post subject: |
One Word!
Timing...
When I put the new distributor on I guess I got the wires mixed up. What a rookie mistake.
