Results of first comp. test in 2000
Joes924
PostPosted: Sat Oct 13, 2001 5:01 pm    Post subject: Reply with quote
I figure some of you might get a kick out of this . Its a reciept of the first time I had probs with my 924 after I bought it all this stuff I could now fix I will take any imput on the comp. check though seems it went like this:
1=130lbs
2=140lbs
3=160lbs
4=90lbs
said something about valves being to tight or burned valves ..
http://www.geocities.com/jod35.geo/repairs.PNG
Go to link for actual reciept from mechanic
remember you might have to click on my home page then come back here if link doesnt work dont ask why ..
Joes924
PostPosted: Sat Oct 13, 2001 5:18 pm    Post subject: Reply with quote
Haynes says compression is around 114 to 156 turns out ..the valves were way out of adjustment due to
the thermo time switch goin out.. causing overheating ..all was restored to normal with adjustment
[ This Message was edited by: joes924 on 2001-10-14 16:02 ]
[ This Message was edited by: Joes924 on 2001-10-15 12:42 ]
