starter question
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Thu Sep 23, 2004 12:55 pm    Post subject: starter question Reply with quote
My starter on my turbo crapped out on me. The question is, will any year 944 starter work on my car? There are a few on e-bay that I am looking at.
Reason I ask is someone has a "later style" permanent magnet type on auction. I don`t think this is an issue as long as the solenoids are the same. TIA
PostPosted: Thu Sep 23, 2004 2:01 pm    Post subject: Reply with quote
PET shows starter part #951.604.101.00 (1.4kw) for all 944, but then for option M198 it shows 951.604.102.00 (1.7kw).
It also shows the 924 Turbo starter as 047.911.023.A (1.1kw), but superceeded to the 944 starter 951.604.101.00.
They show different part numbers for the solenoids for all three starters.
I believe all three starters are interchangeable and you could use any one, but the solenoids aren't necessarily interchangeable between the different starters.
(You probably noticed, but one of those listed on eBay has the beefier case and is apparently an OE 924T starter.)
jpab924
PostPosted: Fri Oct 08, 2004 12:03 pm    Post subject: Reply with quote
Ok, lost that one on e-bay by a few bucks, and my starter miracuously starting working again for a while and now its been dead for a week.
But kind of a curious thought here on my end before I dish out 100 beans on a new or rebuilt 944 unit.
I have 4 wires leading to my solenoid in my 80. Looking through the flow diagrams, I have discovered an "extra" wire runs from 15a on the starter to 15 on the coil. Flipping a few pages over to the 81 setup, I noticed that the wire that ran from 15a on the starter has been eliminated and instead run to 15 (ign on) somewhere into the fuse block.
Mainly I`m asking this question because I am wondering if there is indeed an "extra" 15a terminal on a 944/924s starter. It would keep this matter simple. I wonder if this would also explain the 3 diff. part #s on the solenoids.
PostPosted: Fri Oct 08, 2004 1:06 pm    Post subject: Reply with quote
the 944 starter will work but I am not sure if there soliniod has the booster wire post, so you wouldnt get any spark during cranking only in the run position,
3 928s,
jpab924
PostPosted: Fri Oct 08, 2004 1:15 pm    Post subject: Reply with quote
Hmmmm, this could be a problem. Anyone know for sure if there is an extra post (15a) on the 944/924s starter?
jpab924
PostPosted: Fri Oct 08, 2004 1:51 pm    Post subject: Reply with quote
best pic I could find on-line. Still can`t tell....E-mailed asking him to look for me. Hopefully I hear something tomorrow.
PostPosted: Sat Oct 09, 2004 4:43 am    Post subject: Reply with quote
PET shows the '80 924 Turbo starter is superceeded to the 944 starter 951.604.101.00, so it should have everything you need including the #15 post. Also, the '81-up 931 wiring diagram - it shows an unused #15 post on the solenoid (it's functional - just no wire attached to it).
PostPosted: Sat Oct 09, 2004 10:08 am    Post subject: Reply with quote
deleted
-nick
PostPosted: Sun Oct 10, 2004 8:54 am    Post subject: Reply with quote
The 931 & 944 solenoids are identical (I've swapped them). Also the 1st generation 944 starters will bolt right to the 931 (I'm using one!). They're much lighter. Whether they spin faster is beyond me, although my new one spins much faster than my old one (big surprise).
nick
jpab924
PostPosted: Sun Oct 10, 2004 5:11 pm    Post subject: Reply with quote
Well I bought the one in the pic posted above. $82 shipped. I`ll let you guys know how it goes.
jpab924
PostPosted: Fri Oct 15, 2004 11:42 am    Post subject: Reply with quote
Well, the starter I bought supposedly was off a 951. It bolts right up but I had to resplice two new terminal ends in order to attach them to the solenoid. (15+15a) One I had to cut off the old starter (would not come off) and the other terminal ends eyelet was just a little too small for the bolt...no biggie. But I have to say, it sure does work great! And soooo light compared to that bulky gen 1 starter.
AGD931
PostPosted: Mon Oct 18, 2004 11:56 pm    Post subject: Reply with quote
I had problems with the starter recently, the workshop removed it, cleaned out all the muck, new solenoid, cleaned up the wiring ( I think this was the main problem), and refitted it.
The result is that the starter spins much faster, the engine now starts immediately whether hot or cold.
Arthur
1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia
