jamez Guest
Posted: Fri Oct 05, 2001 11:58 am Post subject: |
My car is leaking oil out the bell housing, its gotta be the rear crank seal right? can it be replaced without pulling the engine out? thanks
Posted: Mon Oct 08, 2001 5:20 am Post subject: |
| If you pull the torque tube and bell housing, remove pressure plate, flywheel you will then expose the rear crank seal. You then will need a "pick" tool or more primatively a screw driver and destroy as you remove the old seal. Installation is as simple as using a large surface hammer to tap into place the new seal. |
