Porver9two4
Joined: 22 Jan 2004 Posts: 104 Location: United Kingdom
Posted: Thu Dec 23, 2004 6:02 pm Post subject: How do i get the fuel tank out of my 924S? |
| I have the dreaded leaking fuel tank in my 924S and need to remove it to replace with a 2nd hand one. How do i get it out? It looks like it wont come out past the gearbox? Any clues? |
Sleykin
Joined: 30 Apr 2003 Posts: 758 Location: Medford, Oregon USA
Posted: Fri Dec 24, 2004 12:20 am Post subject: |
Are you sure it's he tank? More common to have thelines leaking. But if it is the tank, the tranny has to come out first AFAIK _________________ Glenn Neff
Medford, OR
87' 924S |
Porver9two4
Posted: Fri Dec 24, 2004 2:50 am Post subject: |
| Yep, definately the tank - leaking from the bottom, too. Dang, tranny out - that sounds hard! Better study my manual..... |
Posted: Fri Dec 24, 2004 4:15 am Post subject: |
If what you have is just a crease-crack or hole and not a major rust problem that's caused the leak, you could fix it way easier with an epoxy putty repair. I believe there are specific products available for gas tank repair, but years ago, I used PC-7 to fix a leak at the bottom of the tank on my old Fiat 124 Spyder. -Just have to drain the tank, sand the repair area to bare metal, mix and apply the putty, let it dry. _________________ "..it's made in Germany. You know the Germans always make good stuff."
