Llamaguy
Posted: Sun Oct 03, 2004 5:01 am Post subject: smoke and more smoke |
when I first start the car the car wants to die but will stay running if you push the peddle to keep idle speed put in doing so smokes quite a bit. It is also quite difficult to start cold.
note: will stay running perfectly after driving a few yards.
Also when ever I get on it, it starts to start smoking at about 3-4k rpm.
On another note will the turbo fuel injectors that clarks-garage work in our cars? _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
The Fife
Joined: 17 Mar 2004 Posts: 241 Location: San Antonio, Texas
Posted: Sun Oct 03, 2004 5:18 am Post subject: |
| What color is the smoke? |
Llamaguy
Posted: Sun Oct 03, 2004 2:00 pm Post subject: |
I believe it is white at startup and i think blacker when accelerating hard. _________________ 1987 924S Guards Red
Sleykin
Joined: 30 Apr 2003 Posts: 758 Location: Medford, Oregon USA
Posted: Sun Oct 03, 2004 3:14 pm Post subject: |
Sounds a lot like early stages of a bad head gasket. Hydrolocked from sitting blows the steam out for a few mins then runs ok but way rich cause the O2 sensor is hosed from the antifreeze. Sounds just like mine did anyway. _________________ Glenn Neff
Medford, OR
87' 924S |
Posted: Sun Oct 03, 2004 3:47 pm Post subject: |
sorry to say this Llamaguy, but what was one of the first comments I made about this car. _________________ 3 928s, |
The Fife
Posted: Mon Oct 04, 2004 6:36 am Post subject: |
| What is your compression on all 4 cylinders? That's an important piece of information. |
Llamaguy
Posted: Mon Oct 04, 2004 7:45 am Post subject: |
I haven't check the compression,, but my dad said the smoke was in fact black at start up _________________ 1987 924S Guards Red
The Fife
Posted: Mon Oct 04, 2004 8:46 am Post subject: |
| Hmm... well, I'd go ahead and test it anyway. At least you'd know for future reference and the test itself only takes 5 or 10 minutes. |
Posted: Mon Oct 04, 2004 8:50 am Post subject: |
do a compression test, and if your smoke is black that is too rich, meaning a bad tempII sensor probably _________________ 3 928s, |
