Needen explanation for msd
Joes924
PostPosted: Sat Sep 22, 2001 5:06 am    Post subject: Reply with quote
ok need some help here what do i do with the msd 6 is the distribitor a magnetic trigger since theres no pionts .. yes it is.
How do i hook this thing up to the transisterized ignition and piontless distribitor and keep the fuel pump worken ?
Its my 924 ..and I like it/ 1979 924 Joe
[ This Message was edited by: Joes924 on 2001-09-22 11:00 ]
eturbo924
PostPosted: Sat Sep 22, 2001 5:35 am    Post subject: Reply with quote
No idea
What year is your car again?
I would assume that it uses the signal from the points or the hall effect sensor to trigger the system....?
Eric
ricomartinez
PostPosted: Sat Sep 22, 2001 7:46 am    Post subject: Reply with quote
Joe, goto http://www.msdignition.com/ if you don't have the instructions. Hit the "instruction download" link and it will take you to a page with all the instructions for each product they make.
Joes924
PostPosted: Sat Sep 22, 2001 8:25 am    Post subject: Reply with quote
Just have to replace the fuel relay like with an older one, I think thats what Vaugn
said I just put a jumper wire in there not driving it to far I notice it puts pressure in the tank and makes the fuel guage give erraitic readings and i dont think its good for the system, fuel pump etc....
[ This Message was edited by: Joes924 on 2001-09-25 14:34 ]
Alex Roy
PostPosted: Sat Sep 22, 2001 6:06 pm    Post subject: Reply with quote
Well.....Here it is......with the exception of how to hook up the tach, I haven't worked on that yet. Click on the links below for pictures of my system and a schematic I made of my setup.
http://www.geocities.com/manxsyssound/MSDschem.html
http://www.geocities.com/manxsyssound/P1000400.html
http://www.geocities.com/manxsyssound/P1000402.html
http://www.geocities.com/manxsyssound/P1000403.html
http://www.geocities.com/manxsyssound/P1000404.html (should say "Clear/Purple", not "Red/Purple")
http://www.geocities.com/manxsyssound/P1000405.html
http://www.geocities.com/manxsyssound/P1000406.html
Alex Roy
White 924 N/A, Weber DCOE40s, Gemballa body kit
[ This Message was edited by: Alex Roy on 2001-09-22 18:13 ]
PostPosted: Sat Sep 22, 2001 9:10 pm    Post subject: Reply with quote
I apologize that I can't tell you exactly how it works - I haven't put one of these in yet! I am running a Blaster 2 coil without problem, as you are... I'm awaiting delivery of a Permatune ignition box which should be plug-n-play, though much more than the MSD.
If your only problem is the fuel pump not turning on, I'd think about replacing the original fuel pump relay, with the distributor synch function, with a normal relay. Just make sure that it's rated for enough current... what is it, 15A?
Joes924
PostPosted: Sun Sep 23, 2001 2:29 pm    Post subject: Reply with quote
Well it all works fine now ..with Taylor pro series spiral core 8mm performance wires.. check it out/
http://www.geocities.com/jod35.geo/endsummerengine1.JPG
Might have to cluck on my home page then click back to this to get it to work..
[ This Message was edited by: Joes924 on 2001-10-13 15:38 ]
