Joes924 Guest
Posted: Sat Sep 22, 2001 5:06 am Post subject: |
ok need some help here what do i do with the msd 6 is the distribitor a magnetic trigger since theres no pionts .. yes it is.
How do i hook this thing up to the transisterized ignition and piontless distribitor and keep the fuel pump worken ?
Its my 924 ..and I like it/ 1979 924 Joe
[ This Message was edited by: Joes924 on 2001-09-22 11:00 ] |
eturbo924 Guest
Posted: Sat Sep 22, 2001 5:35 am Post subject: |
No idea
What year is your car again?
I would assume that it uses the signal from the points or the hall effect sensor to trigger the system....?
Eric |
ricomartinez Guest
Posted: Sat Sep 22, 2001 7:46 am Post subject: |
| Joe, goto http://www.msdignition.com/ if you don't have the instructions. Hit the "instruction download" link and it will take you to a page with all the instructions for each product they make. |
Joes924 Guest
Posted: Sat Sep 22, 2001 8:25 am Post subject: |
Just have to replace the fuel relay like with an older one, I think thats what Vaugn
said I just put a jumper wire in there not driving it to far I notice it puts pressure in the tank and makes the fuel guage give erraitic readings and i dont think its good for the system, fuel pump etc....
[ This Message was edited by: Joes924 on 2001-09-25 14:34 ] |
Alex Roy Guest
Joined: 29 Jul 2001 Posts: 9063 Location: Royal Oak, MI, USA
Posted: Sat Sep 22, 2001 9:10 pm Post subject: |
I apologize that I can't tell you exactly how it works - I haven't put one of these in yet! I am running a Blaster 2 coil without problem, as you are... I'm awaiting delivery of a Permatune ignition box which should be plug-n-play, though much more than the MSD.
If your only problem is the fuel pump not turning on, I'd think about replacing the original fuel pump relay, with the distributor synch function, with a normal relay. Just make sure that it's rated for enough current... what is it, 15A?
Joes924 Guest
Posted: Sun Sep 23, 2001 2:29 pm Post subject: |
Well it all works fine now ..with Taylor pro series spiral core 8mm performance wires.. check it out/
http://www.geocities.com/jod35.geo/endsummerengine1.JPG
Might have to cluck on my home page then click back to this to get it to work..
[ This Message was edited by: Joes924 on 2001-10-13 15:38 ] |
