Rough idle
jshort75
PostPosted: Mon Sep 17, 2001 3:06 am    Post subject: Reply with quote
Rougher than usual. I have several fuel injected cars. My 77 924 does not fall in the smooth running category along with the others. I have messed with the mixture and checked for vacuum leaks, I even eliminated the vacuum bottle (removed AC) Still idles like a poorly set up Carburated car. New injector seals and all that stuff . Still runs like a truck. I don't get it.
awilson40
PostPosted: Thu Sep 27, 2001 8:19 pm    Post subject: Reply with quote
Check your spray pattern on the injectors at idle. Mine runs great except isnt as smooth at idle as I would like. I'v checked everything and replaced lots of stuff. Its down to a possible problem with the CIS fuel distributor. On one cyl the spray pattern is week at idle but clears up when the rpms pick up. even if I swap injectors, the problem stays with that cyl. so I probably have a clog in the distributor.
