Dave Guest
Posted: Tue Sep 11, 2001 1:37 pm Post subject: |
How do I find out what type engine I have?? I heard there is like a XE, XK and something else. WHat is the difference. Also what kinda transmission do I have. IS there a model number??? I have a 1987 924S with a 5spd if that helps.
eturbo924 Guest
Posted: Fri Sep 14, 2001 6:46 am Post subject: |
| If you look on the passenger side under the hood there should be an aluminum tag with the car type beside that should be the XK XH you are looking for. |
Dave Guest
Posted: Fri Sep 14, 2001 8:05 am Post subject: |
What do the different types mean
Dave Guest
Posted: Fri Sep 14, 2001 8:25 am Post subject: |
Here is my VIN eturbo WP0AA0921HN455230 Tell me what you know The only problem is that when I got the car it had a blown motor. So I got a short block and used some parts from the blown one and some form the short block. So I dont know If I can tell. ANy way let me know everything the VIN will tell you.
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Sun Sep 16, 2001 12:55 am Post subject: |
XK, XG, etc is for the 2.0 liter version, if it's a '87 924S that you have, than the engine code should be M44/07, as it is the 2.5 liter engine from the 944.
Transmission code should be: 016J
for a complete listing check out:
http://www.connactivity.com/~kgross/FAQ/944faq02.html |
