Email: l_porsche@hotmail.com
Date: 20 Jul 2001
Time: 00:31:41I know, I know, enough already with the squiggly lines.~~~~~~~~~~~~~~~~~~~
Here are the parts (hope I got them all)
-931 starter motor
-hatch glass
-right door no damage at all or dents
-all glass, no windshield perfect condition
-head light assembly (both sides)
-80 931 aluminum duct to manifold, the big long
rigid one (pervert)
-1 hub cap (14 inch spoke wheels)
-sunroof clamp (just the lever and pin)
-rear hatch pin receivers, two of them
-door vents (those grilles)
-hood release cable
-speedo cables (there are two, one to wheel,
other to gauge, because of OXS unit)
-wiring harness, rear section only
-suspension (no steering rack tie rods or cvs)
-front 931 nose panel plastic grilles
-front spoiler grille 924 or 931, the black plastic one (no cracks or anything, perfect!)
-931 block with pistons (924/931 block, but 931 pistons)
-crankshaft
-oil pan
-driveshaft
-flywheel
-interior lights/lenses
-window motors (2)
-window regulators (2)
-AC switch, 1980 type (what other years share it?)
-inner rubber shift boot, perfect condition
-side lamp markers
-lighter and socket for it
-heater core (comes right out of that big black heater core housing,
about a foot by half a foot by an inch in dimensions)
-signal indicator wand with wiper wand
-frequency valve
-wiring boot (goes between door and body near hinges)
-air conditioning evap.
-air conditioning condensor
-air conditioning electricals, for nippodesimo, nippledecimal,
whatever.
-radiator
-cold start valve
-gas door
-driver side headlight metal cover
-gas tank
-interior plastic pieces
-wastegate line (one left now)
-82 throttle switches box
-head light switch
-rear defrost switch
-speedo/tach/fuel gauge bezel, no cracks, perfect
-aux air regulator
-green on black clock
-OXS detector thing that speedo cable goes into
-RELAYS
-931 fuel pump relay
-buzzer relay
-flasher signal light relay
-power window relay
-head light dimmer relay
-477 959 143 relay (2 of em)
-171 937 503 relay
