Newly purchased 931 - fuel relay
CMXXXI
PostPosted: Wed Feb 11, 2004 7:40 am    Post subject: Reply with quote
I'm pretty ignorant when it comes to electrical matters. How or why are 924 and 931 fuel pump relays different? This photo shows the 924(L) and the 931(R) fuel pump relay. The only difference I see is that the far right-hand connector is labled "1" instead of "31b". The pin layout is the same, the schematic is the same.
Now, to make matters even more "quizzical", the 433.906.059 relay in the photograph is the actual relay that has been in my 931 ever since I bought it in Germany years ago (never been changed in all the time I've run the car). Does the fact that mine is a 79 Euro without the electronic ignition and lambda and "stuff" make the difference and allow me to use the "924 part number" relay?
(Click photo for larger image)
According to the 924.org Tech Section, there is another 924 fuel pump relay, PN 477.906.059. Is there a difference between it and "the other" 924 relay?
'79 Eurospec 931
Finbarr
PostPosted: Wed Feb 11, 2004 8:02 am    Post subject: Reply with quote
As far as I can tell, there's no difference at all between them. The parts catalogue shows the same part number for both models - 433 906 059 - and for all model years, so the only difference between these two units must just be the physical case size and the pin numbering.
However, looking at the wiring diagrams for early 924 models (up to 1978) shows a labelling the same as Smoothie's photo - 31 is connected direct to ground and 31a is connected to ground via a thing called an "air flow sensor contact". These early models didn't have a connection to the coil supply, so I'm guessing this air flow sensor is somewhere on the inlet manifold and cuts off the fuel if the engine stops.
I can only guess that the newer type of relay can replace the older one, so the original part with the old markings has been dropped and the new one specified as the replacement for all models.
1980 931 (with the odd electrical quirk...)
PostPosted: Wed Feb 11, 2004 11:03 am    Post subject: Reply with quote
Finbarr wrote:
looking at the wiring diagrams for early 924 models (up to 1978) ... 31a is connected to ground via a thing called an "air flow sensor contact". These early models didn't have a connection to the coil supply, so I'm guessing this air flow sensor is somewhere on the inlet manifold and cuts off the fuel if the engine stops.
Some models have a switch built into the fuel distributor. That must be the air flow sensor contact they're referring to.
Obviously my guess at those connections needs updating... say 15 to 12v(+)?, then 31 and 31b to the two coil primary terminals? -Or 31b to ground and 31 to one of the coil connections? Whatever - time for a look at the wiring diagrams...
Nice to know that it might be possible to use one of the cheaper relays in place of the $80 931 part.
John Brown
PostPosted: Wed Feb 11, 2004 2:40 pm    Post subject: Reply with quote
FWIW, I have posted pics of the two relays. You can see that the 924 is much simpler consisting of a single pcb featuring the venerable 555 timer ic; while the 931 is 2 pcbs with 2 1455 ics. Why the extra comlexity is anybodies guess. I always wondered if the cheaper part would work.
http://users.adelphia.net/~johnbrown3/parts10.htm
http://www.meridianelectronics.ca/gadgets/mc1455.htm
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Thu Feb 12, 2004 4:39 am    Post subject: Reply with quote
Clearly I got carried away there overthinking the testing procedure. While it might be interesting to know how the thing works, all that "what goes where" isn't needed to test it. Obviously, if the car runs with 30-87 jumpered and it doesn't run with the relay installed (and it's the correct relay for the car), somethings wrong with the relay. Just remove the jumper and plug the relay in - that's the test.
Well...except for the fact that the relay can be good, but the wiring to terminals 15, 31 and/or 31b(1) might be bad.
PostPosted: Thu Feb 12, 2004 4:47 am    Post subject: Reply with quote
smoothie are you trying to confuse everyone?
3 928s,
PostPosted: Thu Feb 12, 2004 9:15 am    Post subject: Reply with quote
Hey! I got a sudden burst of energy..
For a 931, relay wiring:
31b (or 1) - to coil primary terminal #1 primary(-)
31 - to overboost pressure switch, then to ground (ground for testing off the car)
15 - to 12v(+)
30 - to battery 12v(+)
87 - to fuel pump fuse 25A, then on to both fuel pumps
For '78 na:
31b - to airflow sensor switch
31? - to ground (no terminal number given - guessing 31)
50 - to 12v(+)
15 - to 12v(+)
30 - to fuse, then on to 12v(+)
87 - to single fuel pump
For '79, '80, '81, '82 na:
1 - to coil terminal #1 primary(-)
31 - to ground
15 - to 12v(+)
30 - to 12v(+)
87 - to 25A or 16A fuse, then on to fuel pumps
Connections go to the same places for '79-'82 na and 931's, so it still looks like the cheaper na relay could work in a 931.
Finbarr
PostPosted: Thu Feb 12, 2004 9:29 am    Post subject: Reply with quote
The plot thickens! I've just checked my 931 and it's got the cheaper relay in (and always has as far as I know) - 433 906 059.
Inside it, almost to spite the words of John Brown, is a single PCB with a 1455 IC instead of the old 555.
The merest mention of the 555 has brought back so many memories of electronic projects from years gone by (sighs wistfully) that I'm going to make it my mission to trace the circuit and figure out how it works.
Somebody stop me if it's been done already!
PostPosted: Thu Feb 12, 2004 10:39 am    Post subject: Reply with quote
Very nice. At $21.64, I think I can afford to carry a spare.
433.906.059 is available from www.thepartsbin.com for $21.64 as part number P2037-20302.
-And if that price is too good, you can get it from www.NAPAonline.com for $34.99 as part ECHAR292.
The gold plated 931 relay 931.615.113.00 made of unobtainium is at thepartsbin for $96.90.
The -'78 na relay 477.906.059 goes for $36.01 as P2037-20749 at thepartsbin.
swj
PostPosted: Fri Feb 13, 2004 4:20 am    Post subject: Reply with quote
Ah ha! So that's why the one I found in my glove compartment is the cheaper version too - thanks Finbarr.
CMXXXI
PostPosted: Fri Feb 13, 2004 6:47 am    Post subject: Reply with quote
This "revealation" that the relays do in fact interchange should be good news to all us 931 owners. But curiosity still makes me ask "why are they different inside"? As John wrote: "Why the extra comlexity?" (I'm just glad that there are those of you out there that can make sense of all the electrical stuff. I can deal with the car's wiring diagrams in the manuals, but much beyond that, and it's all voodoo).
'79 Eurospec 931
PostPosted: Fri Feb 13, 2004 10:51 am    Post subject: Reply with quote
Maybe the more expensive one has a rev limiter. My car shuts down slightly above red line (80 931). I'm still using the factory installed original fuel pump relay.
PostPosted: Fri Feb 13, 2004 11:31 am    Post subject: Reply with quote
Wow , the plot just thickened again.
But what about NA's - don't they have rev limiters?
PostPosted: Fri Feb 13, 2004 11:55 am    Post subject: Reply with quote
the 931 rev limiter is the fuel pump relay,
the 924 NA doesnt have have a rev limiter, yah shyadup my peddle got stuck down once.
3 928s,
numbbers
PostPosted: Fri Feb 13, 2004 12:15 pm    Post subject: Reply with quote
No, Lizard, thr '80 931 rev limiter is in the rotor in the distributer. It has a spring and steel ball contactor under the epoxy filled part. At approximately 6300 revs, the centrifical force causes the steel ball to overcome the spring tension, and open the spark circuit.
