Rear Camber adjustment
AppleBit
PostPosted: Fri Jan 09, 2004 2:54 pm    Post subject: Rear Camber adjustment Reply with quote
Ok guys,
This is something I have noted since my new torsion bars. My rear camber is a little too aggressive on the passenger side of the car. At least 8 degrees...
Problem is I can't adjust it any more. What would solve this problem?
- Jon
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
PostPosted: Sat Jan 10, 2004 12:10 am    Post subject: Reply with quote
That's WAY out of the normal range. How are you measuring - known level surface, w/ bubble gauge? Alignment rack?
Camber will be affected by height setting, as well as toe, in the rear.
If these aren't far off, you may have a bent trailing arm.
Good luck...
PostPosted: Tue Jan 27, 2004 12:24 pm    Post subject: Reply with quote
you can't change camber without affecting toe, peter posted some pictures on a camber box modification. It involves mounting the torsion bar in a box arrangement with shims to allow height adjustment.
This allows independent adjustment of the camber without affecting toe in/out. Borrowed from the 935 racers.
would require a bit of effort to set up but takes just minutes to adjust.
my setup is the same i think, as i have sacrificied toe in for the right camber at the moment, something i need to get sorted out soon.
Peter posted a link for an article i sent him, do a search on camber box.
AppleBit
PostPosted: Tue Jan 27, 2004 4:24 pm    Post subject: Reply with quote
leadfoot- you have a URL of where that is at?
PostPosted: Tue Jan 27, 2004 4:38 pm    Post subject: Reply with quote
these are the links to the article...
the post was under bump steer fix, sorry about that...leadfoot
http://www.924board.org/memberdocs/autocross1.doc
http://www.924board.org/memberdocs/autocross2.doc
http://www.924board.org/memberdocs/autocross3.doc
http://www.924board.org/memberdocs/autocross4.doc
http://www.924board.org/memberdocs/autocross5.doc
http://www.924board.org/memberdocs/autocross6.doc
