DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Tue Apr 21, 2009 4:21 am Post subject: |
well im back again after some hard work for the company....i had lunch you can se the ground cable better in this pic.and why didnt i flop that coil outa the way before now!!what a dolt!!
more pollution garb.in the heater hose
well the heater hoses gone,no more water valve(heater valve) almost time to start cleaning up gasket surfaces and getting rid of any small particles and large with the air blower:note the tools there on the sill plate,well the pile has almost doubled on there now!!
quick mock up with the intake!!YAH BABY thats what im talkin about!!!TOO KEWL!!!!!
 _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
DOCO
Posted: Tue Apr 28, 2009 12:10 am Post subject: |
well did a lot of work on the weekend.carbs wont fit!!!too much stuff still in the way.so lets get rid of the rest o the ac stuff.removed the condensor,(had to remove the lower chin spoiler and front bumper)
the hose from the condensor to the receiver dryer
the coolent pipe for the heater has got to go
get inside and remove the a/c fan,evaporator,assembly
4 bolts,2 hoses...and this was the easiest part to remove
cant get the 2 a/c hoses outa the car so out comes the dash
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
DOCO
Posted: Mon May 11, 2009 1:00 am Post subject: |
ok got back into the too fah on saturday....oh by the way dont be like me and just jump in without reading about what yer doin first seems to be a mechanic thing,after working on cars for 35 years you have this thing about you can repair anything even if you dont have the knowlage.so after searching and finally finding the dash removal info. on friday night,i found out saturday even if i got the dash out it wouldnt have helped so how can i get these a.c hoses out without cutting them?dont want to be a butcher and someone is gonna need this stuff!!wow one little nut and the center vent is pulled out!!wow anouther big retaining clamp(found out about this in the search and tech section)and the whole heater box is loose!!couple of heater hoses and this moves just out enough that i can snake one a.c hose out through the engine side and one into the pass.compartment!!! yes this has been a very good and humbling learning xperience for me wll enough of my yammering heres some pixs....oh ya some were wondering why i had a roll of duct tape on the front battery tray....well see ifin ya can guess why in the pics...remember we dont want dirt and or little greebly critters gettin in any where....so back to the show
oh man dont really want to pull the interiour apart to get this dash out!!!not yet anyway
one large wire clamp and down comes the heater box
ya the a/c hoses are up there somewhere
well the thinner hose is out and came out nicely through firewall aand into the engine compartment
just a wee bit closer shot
remove the rubber sealing rings to ade in removal of the hoses and we have the large dia.hose into the cockpit
just snake it through from behind the heater box and wahla the a/c hoses are out!!!!! Yay!!!!! guess what still need to remove more stuff around the engine carb still wont fit hey its all in fun or i wouldnt even bother  _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Mon May 11, 2009 2:47 am Post subject: |
Have you got a plan to replace that coolant pipe? You know you can't run without it, right? _________________ Toofah King Bad
DOCO
Posted: Mon May 11, 2009 8:05 am Post subject: |
thanks for the info rasta.i was thinking of useing a flushing tee and just running 2 rubber heater hoses.or ill just have to reroute the steal tube lower somehow.illl worry about that when i get there _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
icdpride
Posted: Thu Jun 04, 2009 8:16 am Post subject: |
I have a small question for you when you take out the a/c condenser from behind the glove box did you just disconnect the hoses and then leave them disconnected or did you just cap them? thanks _________________ 1977 half red half primer 924 |
!tom
Posted: Thu Jun 04, 2009 9:49 am Post subject: |
| icdpride wrote: | | I have a small question for you when you take out the a/c condenser from behind the glove box did you just disconnect the hoses and then leave them disconnected or did you just cap them? thanks |
Umm. Look at a couple posts above this one. It clearly states that he pulled the hoses out through the firewall, so he neither left them nor capped them -- he removed them. _________________ 78 924 NA
5-lug |
icdpride
Posted: Thu Jun 04, 2009 4:13 pm Post subject: |
| !tom wrote: | | icdpride wrote: | | I have a small question for you when you take out the a/c condenser from behind the glove box did you just disconnect the hoses and then leave them disconnected or did you just cap them? thanks |
Umm. Look at a couple posts above this one. It clearly states that he pulled the hoses out through the firewall, so he neither left them nor capped them -- he removed them. |
oh yeah wow I am an idiot _________________ 1977 half red half primer 924 |
DOCO
Posted: Fri Jun 05, 2009 1:48 am Post subject: |
never is an asked question bad nor make you an idiot.the only idiot is the one that doesnt ask.there tricky and it can be done.if you need more info on what to remove and what you do not have to remove.dont try and take out the dash it is not nessary nor is it helpful.pm me and i can guide you through that mess.  _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
DOCO
Posted: Sat Jun 27, 2009 3:11 am Post subject: |
well closer and closer!!starting to get excited.finally removed the air pipe down to the exshast.....bolted down the intake for good...and mock up with the carbs!!!!yay the fit!!!i knew they would just some perservirancne(man i gotta go back to school my spelling sucks)heres some pics SWEEEEET!!!!!!
vroom vroom soon!!!!WOOHOOOOO!!Ya man thats cool!! _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Sat Jun 27, 2009 3:23 am Post subject: |
Awesome!!!!! _________________ erstwhile owner of just about every 924 variant ever made |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Sat Jun 27, 2009 3:51 am Post subject: |
I hope you moved the frigging house lamp - they have a way of getting between your feet and the pedals. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
DOCO
Posted: Sat Jun 27, 2009 5:41 am Post subject: |
NOPE still in there!!!! need so i can put back together all the stuff i didnt need to take apart but soon she'll run and no house lites gonna stop er!!!and i dont think the brakes will either  _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
DOCO
Posted: Sat Sep 12, 2009 12:51 am Post subject: |
just bumpin this up cause ive got some new stuff to add this weekend!!!
VROOOM VROOM getting closer!!!Yah Man gotta like it  _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Vince Ponz
Posted: Sat Sep 12, 2009 2:21 am Post subject: |
Filter on the gas lines???? _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
