PopUpProject
Posted: Tue Feb 17, 2026 11:32 pm Post subject: Wiring harnesses and what to do with the relay box? |
Hey guys,
I've gone on a side quest while trying to figure out the brakes still. I wanted to try and get the window to roll up on the car and I discovered the nightmare that is the relay and fuse box.
I've read the sticky and a couple other posts about the wiring on these cars and it is not looking fun. My relay box under the dash is MESSED UP and extremely corroded in all of the blocks that had missing relays. Is there any hope of disconnecting the blocks (since it looks like they go together like legos) and cleaning them out? I believe with the fuses I'll be able to clean up the contact points and put in new fuses, but not totally sure what to do about the one missing contact
My plan was also to try and restore the wiring back to factory as much as possible and use oem style harnesses because whoever wired this car during its journey created chaos. I have not been successful in finding any harnesses, but it is also hard for me to search for part numbers as I don't know fully what's there, what's not, and what has been rednecked. Is there anywhere that has oem style harnesses premade?
Here is a video of the nightmare https://drive.google.com/file/d/1-5xPucGCBHtrMK--Jzxv7uHUsgvwp848/view?usp=sharing _________________ Just trying my best to figure this out without total failure
Poppy the '82 924 Resurrection in Progress |
chuck21401
Joined: 20 Feb 2005 Posts: 606 Location: Annapolis, MD
Posted: Thu Feb 19, 2026 12:04 am Post subject: |
| Quote: | | My relay box under the dash is MESSED UP and extremely corroded in all of the blocks that had missing relays. Is there any hope of disconnecting the blocks (since it looks like they go together like legos) and cleaning them out |
I've had to pull down the fuse box a couple of times.
One time was chasing a gremlin related to the fuel pump relay and the other time was for the running lights.
Some of the relays plug into removable blocks. In my case I replaced all of the connectors at the fuel pump relay. It wasn't easy to strip the wires and get the crimping tool there. And that was only like 5 connectors.
The connectors had some corrosion so I replaced them.
| Quote: | | Is there anywhere that has oem style harnesses premade? |
I haven't come across a full harness for the 924/924 turbo. Kroon Wiring harness makes a handful of 924 wiring products and they are willing to recreate a harness if you send the original to them. Here's their website: https://www.kroonwireharnesses.com/index.php?route=common/home
I can't imagine what that would cost.
Another idea would be to contact DC Automotive in NC. https://www.dcauto.com/. They have different wiring harnesses on Ebay from time to time: https://www.ebay.com/sch/i.html?_ssn=porschepeople&store_name=dcautomotiveporscheparts
Maybe they'd be willing to pull everything from a 924 that they are parting out?
Another idea would be to acquire a parts car and move the harness over.
| Quote: | | but not totally sure what to do about the one missing contact |
What do you mean? On the main fuse box or the auxiliary board? In my quest to solve problems with my fuel pump wiring, I acquired NOS copper contacts for the auxiliary board but didn't end up installing them. I believe the part number is 99965227510. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
chuck21401
Posted: Thu Feb 19, 2026 12:13 am Post subject: Re: Wiring harnesses and what to do with the relay box? |
What does the switch do? Turn on the fuel pump?
 _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
PopUpProject
Posted: Thu Feb 19, 2026 5:29 am Post subject: Re: Wiring harnesses and what to do with the relay box? |
| chuck21401 wrote: |
yeahhhhhhhhhhhh the black switch is the fuel pump/KJET thing and then the red switch is a combination of my headlights and sidemarkers, but the button for the lights also sorta works.
| chuck21401 wrote: | | What do you mean? On the main fuse box or the auxiliary board? In my quest to solve problems with my fuel pump wiring, I acquired NOS copper contacts for the auxiliary board but didn't end up installing them. I believe the part number is 99965227510. |
Well, I guess both. I'm missing lego block #4 (which according to the fuse and relay diagram is the "Headlight cleaners*" but I didn't think these had headlight cleaners nor do I know what the * means. Not sure if I'm missing the wiring for this dude all together or if the block just doesn't exist. I'm afraid to look.
And fuse wise I am also missing the contacts for auxillary fuse #7 (Rear fog light) and I know there is wiring in my hatch for the third brake light (which is what I'm assuming rear fog light means), but I'm not sure if the wiring goes all the way up to the aux panel or if it disappeared into the depths at some point in time. _________________ Just trying my best to figure this out without total failure
PopUpProject
Posted: Thu Feb 19, 2026 5:36 am Post subject: |
| chuck21401 wrote: |
This might be the best route for me unfortunately if I can't get my hands on some new harnesses or good conditioned harnesses. Where did you find the connectors and the crimp tool?
I ordered an expansion tank from DC Auto before, but it unfortunately was cracked and they didn't have any other in stock after I pressure tested it when it arrived to me. But it doesn't hurt to ask and see if they could test the wiring before I purchase it as they wouldn't pressure test the tank. _________________ Just trying my best to figure this out without total failure
Beartooth
Posted: Thu Feb 19, 2026 5:39 am Post subject: |
My 931 had/has similar issues - maybe not as bad. I'd dig up something called Deoxit (a deoxidizer for electronic connectors and components) and give every contact a squirt. One issue I had was my blinkers would barely cycle, or sometimes blink once and stay on; once I cleaned up the blades on the breaker and the socket, it worked fine. That switch Chuck pointed out sure looks like somebody's temporary (hopefully) solution for a bad relay. I just used a jumper wire while I was working to get my car to run, and I think that's ok when you're just working to get it going. I'd have about the same answer on the wiring harness - it's probably going to be a custom job and very expensive. But the good news is, your fuse and relay boxes don't look any worse than mine, and my car has been functional enough to put on over 6000 miles. The fuel pump circuitry has been the one big problem: I've had a couple no-starts and died on the street once because of losing contact at the fuse. 924ACR has a post somewhere in which he details spicing a blade socket and fuse in place of the original fuse. Anyway, I can say the electrics are one of the biggest trouble spots on these, but most likely you can clean up what you've got, and you should only have a few things to fix or bypass. _________________ 1980 931 diamond in the rough |
chuck21401
Beartooth
Posted: Thu Feb 19, 2026 3:12 pm Post subject: |
You can find anything you'd need at a parts store, but for the price of a handful of connectors, you can buy an assortment online with a hundred or so pieces of the same or better quality that will come in handy down the road. Lowe's or Home Depot will have the standard wiring multitool (has a cutter, stripper, terminal crimper, and a few other things built in), as well as assortments of terminals - but they're pretty low-grade. Definitely investigate anything you're buying online - the low-grade stuff will probably work, but you get what you pay for to some degree. I buy a lot of stuff like that from Summit Racing; not the cheapest source, but they're reasonable and have always had great service if I've had an issue. https://www.summitracing.com/search/part-type/wiring-terminals $50 worth of terminal assortment and wiring tool should get you going. I've also bought a ratcheting crimper and a variety of terminals, but you don't need much to start. _________________ 1980 931 diamond in the rough |
PopUpProject
Posted: Thu Feb 19, 2026 11:11 pm Post subject: |
Thanks Chuck and Beartooth, I'll have to get to hunting for supplies. I'm planning on starting with the fuses as I think it'll be the easiest to start (and I need that stupid window to roll up because winter) I will get to the relay panel eventually as honestly I'm afraid to touch something and then the car stops running. Do you happen to remember off hand what gauge and size spade connect we need?
I will report back with cries for help if things go south once I get started. _________________ Just trying my best to figure this out without total failure
Last edited by PopUpProject on Thu Feb 19, 2026 11:19 pm; edited 1 time in total |
Joined: 29 Jul 2001 Posts: 9064 Location: Royal Oak, MI, USA
Posted: Thu Feb 19, 2026 11:13 pm Post subject: |
Yeah, those brass terminals are super-common and easy/cheap to replace; it's just a matter of getting a good properly-executed crimp on them.
$0.26 each at Newark Electronics, where I got 'em for my rewiring...
https://www.newark.com/amp-te-connectivity/60249-1/terminal-female-disconnect-0-81mm/dp/99B2261
I got my crimpers from Cycle Terminal, and I find them excellent (along with the instructions he has for how to properly execute good crimps).
I really dislike anything bought from the local hardware or auto parts store - it's all the cheapest Chinese junk, and while it'll do in a pinch for roadside repairs, the objective here is making things better than 20-40-year old wiring, which means high quality new connectors and good quality tools, proper heat shrink to keep the water out, and good execution.
Unfortunately, just putting new connectors on the old wires isn't quite as awesome as all new wire - since water can wick up inside the insulation and cause corrosion there too - but it's easily 80-90% of the way there.
I have also used brass/silver polish - Tarn-X - on my connectors, especially the ground connections hard-mounted to the body, since they can't really be replaced - and I've found it to do wonders... very easy to use with an old toothbrush and get in all the nooks and crannies... _________________ Vaughan Scott
PopUpProject
Posted: Fri Feb 20, 2026 3:16 am Post subject: |
| 924RACR wrote: | Yeah, those brass terminals are super-common and easy/cheap to replace; it's just a matter of getting a good properly-executed crimp on them.
I have also used brass/silver polish - Tarn-X - on my connectors, especially the ground connections hard-mounted to the body, since they can't really be replaced - and I've found it to do wonders... very easy to use with an old toothbrush and get in all the nooks and crannies... |
Thanks Vaughan! I had picked up some Tarnx when I first fixed the side marker wiring because the harness I got from the donor car had some corrosion on the terminals, so good to know I can use it up in there as well!! Also toothbrush strategy is a good idea, I was using a qtip and it worked but wasn't stiff enough to clean easily.
I haven't had to crimp wires in a long time, so this will be an adventure _________________ Just trying my best to figure this out without total failure
Posted: Sat Feb 21, 2026 1:03 am Post subject: |
Most important thing to get those crimps done well: a reference for what is a good crimp, and why.
Cycle Terminal, in addition to selling very good tools at a reasonable price for the hobbyist, has EXCELLENT detail on this with photographic examples on his website:
https://www.cycleterminal.com/crimp-tools.html
It's a must read if you want to do a good job; just scroll past the tools to about halfway down where he shows what good and bad crimps look like. _________________ Vaughan Scott
Raize
Posted: Sun Feb 22, 2026 6:35 am Post subject: |
Get a set of de-pinning tools, it makes it a lot easier and you will be able to de-pin all sorts of connectors on the car if needed.
None of the relays will stop the car from running except the fuel pump relay.
Given the corrosion, I would ask, is the battery tray solid? |
PopUpProject
Posted: Sun Feb 22, 2026 11:27 pm Post subject: |
| Raize wrote: | Get a set of de-pinning tools, it makes it a lot easier and you will be able to de-pin all sorts of connectors on the car if needed.
Good to know not to mess with my rednecked switch until I'm ready to brick the car for a long time, but I could work on the others if I wanted to, thanks Raize!
With me being a LHD car, the battery is on the opposite side from the relays for me, but the open space tray thats above it is pretty solid. I have to give it a good vacuum and make sure there's no pin holes because I got some leaf build up in there, but the battery tray side is also pretty solid. I'll have to grab some pictures next time I stop out at the car and make sure there's nothing that I'm not seeing that yall know is a sign of bad news.
My big concern is honestly the missing relay block. Was that an option? Did it exist kinda like modern cars where the block is (was) there but had no wiring ran? Am I going to find a bunch of wires that some how haven't burned the car down from being detached and just hanging out back there? The star on the diagrams makes me believe that it was an option, but I haven't been able to find a solid answer. And if I did have headlight washers, they don't exist on my bumper and I'm not sure where else they would be.
The running theory we have on this car based on how salt gunked the carpets were and the seat bolts being basically one with the car, is that the last time it was a fully on the road car it was snowing out and whenever they got in the car, they left behind chunks of snow and salt that made its way around on the inside. The good news is the floor pan from underneath is solid. I just haven't ripped up the carpet yet to make sure the top side is good. I really don't wanna rip up the carpet if I don't have to because that's gunna be a pain. _________________ Just trying my best to figure this out without total failure
Raize
Posted: Mon Feb 23, 2026 7:52 am Post subject: |
Might be that the options were in all the looms but the relays and the actual hardware not present. Probably just the previous owner couldn’t afford relays or stole them for something else.
You’re missing in the top row:
Fuel pump
Fog lamp (think these hang below the front bumper, or it might refer to rear fog lights which are in the rear light cluster)
Seat belt warning (lol)
Rear window defogger
And in the bottom row:
Headlight flasher relay (low beam high beam switch)
Extra headlight relay (these are in the front bumper)
Fan relay (not strictly necessary)
Power windows is the one hanging on its own. |
