ZF LSD's
simsport
PostPosted: Wed Sep 22, 2004 3:50 am    Post subject: ZF LSD's Reply with quote
Can anyone answer this...
Is the ZF LSD fitted to the snailshell NA 924 box the same in all respects as the one fitted to the 931 snailshell box ??
I have a chance of one from a NA 924 and wanted to fit it to my 931 box.
Also, anyone got a picture?
Cheers
Simon
Blown is always best!
Lizard
PostPosted: Wed Sep 22, 2004 4:01 pm    Post subject: Reply with quote
I am sure that the differential is the same in the 016/z trannies as they are in the G31, if you have any questions just measure the OD for the ring gear and they should be the same if they are you are good,
keep in mind you will need to bolt your ring gear onto the other diff
3 928s,
CMXXXI
PostPosted: Thu Sep 23, 2004 2:39 am    Post subject: Reply with quote
"According to PET"... the differentials AND the LSD components used in the G31 series boxes are different than those found in the 016 series gearboxes. The G31 components carry "930" series part numbers and the 016 components carry "944" series part numbers. This is NOT to say that there aren't some some common bits, plates, gears, etc, but the major components have different numbers.
'79 Eurospec 931
