opmatt21
Joined: 29 Jul 2001 Posts: 8794 Location: Royal Oak, MI, USA
Posted: Mon Sep 06, 2004 11:14 pm Post subject: |
That's the one I'm using on my racecar, from crank-scrapers.com. Excellent product, minimal fitting required (though not completely bolt-on - they never are). I would recommend them (from these guys), if you are in need of one.
Do you need one? Hard to say. If you're not racing and not rebuilding a motor - I certainly wouldn't bother. I still don't have an oil pressure sensor plugged into my data system, so I still don't know how much the scraper helps on turns. I do know my engine pulls hard and holds oil pressure OK, but there are many things I've changed, so who knows how much of that is a crank scraper. _________________ Vaughan Scott
Kevin Johnson
Posted: Fri Sep 10, 2004 12:29 am Post subject: Re: Do crank scrapers work? Yes. |
We just did dyno work on a 993cc SOHC three-cylinder Metro engine. The design was one that attaches to the main caps like on the 924.
This engine also has a full windage tray that isolates the sump oil from the rotating assembly.
Horsepower increased an average of 3% (over four pulls the data ranged from 2.5% to 3.5%). Power increased from roughly 2750rpm to 5300rpm.
Laugh! I sure wish we had the money to actually be one of those "As-Seen-On-TV" people."
Kind regards,
Kevin Johnson
Ishihara-Johnson Crank Scrapers |
Posted: Sat Sep 11, 2004 1:11 am Post subject: |
Very interesting! 3% on a Metro engine... just enough to whip the cream off a custard, as the Brits say? Still, interesting to see such a gain even with a stock windage tray.
Welcome to our forum!
I'm hoping to get my car on a Dynojet before too much longer here, now that it's broken in. Of course, it's not entirely stock, being race prepped - 9.5:1 CR and 0.040" overbore, balanced and blueprinted... but other than that and a race exhaust, it's fairly stock... will be sure to post results... _________________ Vaughan Scott
Kevin Johnson
Posted: Wed Sep 15, 2004 4:31 am Post subject: |
Just heard back from a Honda racing team that received some scrapers for evaluation about 7 months ago. They picked up between 1.5% and 3% hp depending on rpm with the D16 scraper -- this despite the girdle structure that runs along the mains.
Kevin
924RACR wrote: | Very interesting! 3% on a Metro engine... just enough to whip the cream off a custard, as the Brits say? Still, interesting to see such a gain even with a stock windage tray.
I'm hoping to get my car on a Dynojet before too much longer here, now that it's broken in. Of course, it's not entirely stock, being race prepped - 9.5:1 CR and 0.040" overbore, balanced and blueprinted... but other than that and a race exhaust, it's fairly stock... will be sure to post results... |
MikeDanger
Posted: Fri Sep 17, 2004 2:22 pm Post subject: |
do you make them for the 944 turbos? |
Kevin Johnson
Posted: Fri Sep 17, 2004 8:55 pm Post subject: |
MikeDanger wrote: | do you make them for the 944 turbos? |
Hi Mike,
I would love to -- I just need access to a short block for measurements. Hoepfully someone in the FL area will be able to lend one out.
Kind regards,
Kevin |
MikeDanger
Posted: Sat Sep 18, 2004 1:00 am Post subject: |
check with broadfoot racing i believe they are in florida |
