badenkb Guest
Posted: Tue Aug 21, 2001 4:42 am Post subject: |
Hi All
How easy is it to replace the windscreen on a 924 na ?
Never tried a bonded screen before.
Don't suppose its just a matter of reomving the old one and then glueing in the new one ?? (and what glue is used???)
Any help appreciated
thanks
Ian
77 924 |
wdb Guest
Posted: Tue Aug 21, 2001 7:44 am Post subject: |
I would suggest letting your local glass shop do it.If you do it you will probably buy the gasket cutter ($15 or so ) L shape bladed tool ,to get under glass and cut through the adhesive and gasket.solvent to disolve and clean up remaining adhesive and gasket ($10 or so),new adhesive ($10 or so),an hour or so cleaning.If not installed properly,the possibility of body twisting,and sudden shock from a pothole or steep drivway could transfer to glass and crack it.some times, it just makes sense to pay someone to do it for you. If your interested,or cant find replacement glass heres a link to light weight and plastic wind screens
http://www.racingshields.com/
Vince Ponz Guest
Posted: Tue Aug 21, 2001 11:27 pm Post subject: |
| I had two windshields done by a pro in my driveway. Cost in NY dollars $195. Took about an hour. |
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Wed Aug 22, 2001 3:17 am Post subject: |
And if the pro breaks it going in, he runs to the store and gets another no cost to you.
_________________ Bob Dodd - 924turbo@cox.net
I have Way too many cars, parts for the 931,944 and 951 |
badenkb Guest
Posted: Wed Aug 22, 2001 7:16 am Post subject: |
Thanks to all - I think I'll let the pros install it...
Ian |
