931 transaxle oil change
J1NX3D
PostPosted: Sun Aug 22, 2004 12:34 am    Post subject: 931 transaxle oil change Reply with quote
Hi guys,
A run down on how, what oil and what tools if u please! The haynes isnt too helpful. Im hoping to get this done and flush the brakes later this week. I have the old snail shell.
TIA!!!
'86 944
PostPosted: Sun Aug 22, 2004 5:33 am    Post subject: Reply with quote
I have the Audi trans, so can't tell you for sure what size tool and what gear oil to use, but I use 85-90w gear oil and the cutoff end of a correct size (something like 17 or 19mm - I need to verify which) big ol' hex key in a socket wrench.
Most important is to be sure the top (fill) port can be opened before you remove the lower plug - otherwise you could end up needing to turn the car upside-down to refill it.
arnhemcr
PostPosted: Sun Aug 22, 2004 7:44 am    Post subject: Reply with quote
Folks
it's a 17mm hex for both the filler and drain plugs. The problems you face are:
- very limited clearance around the filler plug. A plug key 40 mm in length would have done it but the short arm of an Allen key, around 80mm, was too long.
- getting the fluid in. Above the filler plug there's room for a 1 litre bottle to drain by gravity. Otherwise you'll have to pump the fluid in from below.
best wishes Andy
924 Turbo, 1982, Euro spec., RHD
PostPosted: Sun Aug 22, 2004 3:19 pm    Post subject: Reply with quote
it is a 17mm allen key, here is what you do to get it out, go to a VW dealer or somewhere that you can find a REGULAR 17mm allen key and then cut a couple inches off the end and then stick it in the fill plug and use a wrench to get this plug out BEFORE you remove the drain plug!
3 928s,
PostPosted: Sun Aug 22, 2004 3:55 pm    Post subject: Reply with quote
Yes - 17mm - Should be relatively easy to find since VW's and Audi's use the same tool.
I cut a piece 30mm long off the end. See this pic and the one after it -
http://f2.pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/341f&.dnm=b317.jpg
CMXXXI
PostPosted: Tue Aug 24, 2004 2:52 am    Post subject: Reply with quote
What I did was to buy a cheap 17mm hex key socket (?Auto Zone?) and simply punched out the press-fit hex key.
'79 Eurospec 931
PostPosted: Tue Aug 24, 2004 12:35 pm    Post subject: Reply with quote
Back when I couldn't afford special tools, I used a lug bolt that had a 17 mm head. I jammed a 17 mm nut on it and cut off the rest of the bolt.
Pop it in, then use a 17 mm box wrench to turn.
-nick
PostPosted: Fri Aug 27, 2004 2:51 am    Post subject: Reply with quote
Ditto on Paul's method. There is no room to get a socket in there and I had a tough time finding a regular allen/hex wrench that large. Someone was really asleep when they came up with the design on this one.
-nick
