Hood release cable
rockola
PostPosted: Thu May 27, 2004 5:19 am    Post subject: Hood release cable Reply with quote
Short question: will the hood release cable from a Golf/Rabbit work in the 924? If not, is there another that will?
1984 indischrot 924
PostPosted: Thu May 27, 2004 8:22 am    Post subject: Reply with quote
Short answer $18 US for a new one, why bother?
rockola
PostPosted: Thu May 27, 2004 3:41 pm    Post subject: Reply with quote
'cause I need it NOW, and experience suggests the local Porsche dealer won't have it on the shelf.
EDIT: I checked, they didn't, and it would cost 52,50 Euros through them, with today's exchange rate that's $63 US and change.
1984 indischrot 924
78porsche924
PostPosted: Thu May 27, 2004 5:20 pm    Post subject: Reply with quote
Should be the same as the 944 i would assume and my dealer carries the sunroof clips for 944s. If you really wanted to you could use bicycle brake cables if u rigged it up correctly i would assume if u really are in a pinch.
90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
PostPosted: Fri May 28, 2004 7:29 am    Post subject: Reply with quote
If your looking to get McGyver-ish..
I recently replaced the inner twisted cable of a lawnmower control with some 16 gauge solid wire exactly like this -
(click small pic for large)
Here's the mower fix -
I used small machine screws, nuts and washers at both ends to terminate the wire. If so inclined, you could do something similar to this with the hood release cable if the outer sheath is reusable. There are no sharp bends, so a solid wire would work fine. Grease it as you slip it in.
I measure the OE hood release inner cable at .057" (1.45mm) and the 16 gauge galvanized solid wire at .063" (1.6mm) - probably close enough for the 16 ga. wire to fit.
