924 with bad noise
fcapri
PostPosted: Sun May 23, 2004 6:12 pm    Post subject: 924 with bad noise Reply with quote
hi
I bought a 924 (my first one ) and its having a little problem, when the engines runs, it makes a bad noise. something rattling from the bottom.
the engine didn't run when I bought the thing, because the salesman told me that the oil pump was broken.
could it be the pump? when the engine runs, the oil pressure is at 2bar, and there is oil on the cam shaft, so the pump is still working.
it appears that the sound is coming from the direction of the clutch.
and where could I find the oil pump?
ps: i'm still reading all the topics, and it is possible that I will find the answer later
Jazzerpet
PostPosted: Sun May 23, 2004 9:30 pm    Post subject: Reply with quote
The oil pump is located at the front of the engine around the crank.
1985 ½ 944
Member of the “Omaha Crew”
Sleykin
PostPosted: Mon May 24, 2004 12:49 am    Post subject: Reply with quote
What year?
Glenn Neff
Medford, OR
87' 924S
PostPosted: Mon May 24, 2004 12:56 am    Post subject: Reply with quote
Doesn't sound like there's an oil pump issue offhand - should be 2 bar at idle except when hot it can dip as low as 0.5-1.0 bar, and around 4-5 bar at speed.
However, it is important to isolate if the noise is internal or external to the motor.
PostPosted: Mon May 24, 2004 2:28 am    Post subject: Reply with quote
Also post the transmission type (mainly whether it's auto or manual) and other conditions - sound changes while moving? in or out of gear? coasting out of gear? changes on left or right turn, stopping, accelerating, etc.
fcapri
PostPosted: Mon May 24, 2004 4:00 am    Post subject: Reply with quote
Sleykin wrote:
What year?
1976
PostPosted: Mon May 24, 2004 8:46 am    Post subject: Reply with quote
sounds like bearings though if theres no metal shavings in the oil
thats not it.
welder
PostPosted: Mon May 24, 2004 10:38 am    Post subject: Reply with quote
When you rev the motor, does the rattle increase with the rpm's, or is it just constant? Is it a sheet metal sound, or definately inside the motor?
I have a 78 n\a currently under restoration.
fcapri
PostPosted: Mon May 24, 2004 6:34 pm    Post subject: Reply with quote
yes, sometimes, when he is idling, the rattling stops, but once you rev it, the rattle increases with the rpms.
first I thought it was the alternator, because the turning thing has metal missing ont the side. like it has been rubbing against another peace of metal. but the sound is not coming from the front.
its more the intake (or below the intake) or it is coming from the clutch
78porsche924
PostPosted: Tue May 25, 2004 2:40 am    Post subject: Reply with quote
First things first, do the cheap and easy thing, check the exhuast heat shields under there. Also check the exhaust clamps if there are any. Might just be something as simple as that. It happened to my sisters car and her and my parents thought the tranny was shot. Exhaust clamp rusted and broke and rattled like crazy. Took 5 minutes to diagnose and fix.
90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
gohim
PostPosted: Tue May 25, 2004 3:22 am    Post subject: Reply with quote
Rattles....
Sometimes it is hard to aisolate exactly where they are coming from.
At the front, could be a cracked timing cover. On the 924, the timing cover is mounted with holes with rubber grommets, and metal sleeves that go inside. The rubber rots, and the timing cover vibrates until the metal around the hoels crack, and then they can make a buzzing sound.
The sheet metal heat shield on the top of the exhaust manifold that is supposed to help protect the spark plug wires has a tendency to crack and buzz/rattle also. The later model year cars have an improved part.
Also the exhaust manifolds themselves have a tendency to crack on the early cars. The cracks grow from the bottom, and in an advanced stage can grow up into the top, but will be concealed by the spark plug heat shield. Later model exhaust manifolds are reinforced on the bottom side with huge ribs. New replacement exhaust manifolds for early cars also have the big reinforcement ribs. You can crack for cracks on the bottom of the exhaust manifold with a mirror, from under the hood, without crawling under the car.
Early cars with a EGR filter and tube (mounted on the left side of the engine block). The EGR filter has a tendency to rot out on the bottom, so you need to check the side against the engine block with a mirror. The tube that runs to the exhaust also cracks from fatique, and will buzz.
80 and later cars can crack the downpipe at the lower end support, where the downpipe is joined to the cat adapter pipe. This can also buzz.
numbbers
PostPosted: Tue May 25, 2004 9:06 am    Post subject: Reply with quote
Well guys, I have had a rattle for several years, and it is definitely in the exhaust. To be more specific, in the cat. I have had it off and you can hear the rattle when you shake it. I assume the substrate has crumbled and is ratling. Someday, I will cut a hole in it and dump out the crap, then weld it back up.
fcapri
PostPosted: Wed May 26, 2004 6:11 pm    Post subject: movie Reply with quote
I made a little movie of the engine when it rattles.
http://users.skynet.be/fa438830/porsche.avi
it has been compressed with divx 5.1.1
PostPosted: Thu May 27, 2004 1:01 am    Post subject: Reply with quote
Nasty sound.
It's reminding me of the last time I had a connecting rod bearing failure on the Honda. No offense intended though.. a Porsche can sound a little like a honda when the Porsche's sick.
PostPosted: Thu May 27, 2004 8:37 am    Post subject: Reply with quote
Please drain the oil and check for metal, that sounds like a rod bearing to me. If it is, you will find a lot of metal in the oil.
DON'T START IT AGAIN!
