Adjustable front coil overs
Alex Roy
Guest
PostPosted: Fri Jan 18, 2002 3:12 pm    Post subject: Reply with quote
I was wondering if anybody knew if the adjustable coil over setups for the Rabbit/Gulf/Jetta would work in the 924 since much of the front suspension is similar.
PostPosted: Fri Jan 18, 2002 11:35 pm    Post subject: Reply with quote
The front suspension _is_ the same, down to the part numbers, as far as the strut and a-arm basics (though slightly different for swaybar attachments), and they do work and are interchangeable. Check out the front struts on my racecar, on my website.
Alex Roy
Guest
PostPosted: Sat Jan 19, 2002 5:50 am    Post subject: Reply with quote
Could I also use the front suspension bushing kits for the A1 Rabbit/Jetta in that case? If so, which of the following sets are applicable on the follwoing page on JCWhitney.com:
http://www.jcwhitney.com/product.jhtml?CATID=141218&FID=1168&BQ=jcw2
Alex Roy
White 924 N/A, Weber DCOE40s, Gemballa body kit
[ This Message was edited by: Alex Roy on 2002-01-19 06:51 ]
PostPosted: Tue Jan 22, 2002 1:43 am    Post subject: Reply with quote
Yeah, that'd work; I put in a set of full spherical bearing inserts for Golf/Rabbit in my car. I believe you'll be wanting the 81ZX8388T part, that looks like the one for the a-arm bushings.
AppleBit
PostPosted: Tue Jan 22, 2002 2:53 am    Post subject: Reply with quote
DST Racing just came up with a setup not to long ago. I am buying a set today for my car I can't wait to put it on!!!!!!
- Jon
