badenkb Guest
Posted: Sat Jan 19, 2002 8:21 pm Post subject: |
HI
I am having some difficulty setting these clearances to book spec.In particular, on the exhuast valves , at maximum adjustment my clearance is still very large - is it likely that I have very worn springs on the valve ?
The camshaft is a good condition second hand and the cam follower is new.
Thanks for any help
Ian
77 924 |
Joes924 Guest
Posted: Sun Jan 20, 2002 10:13 am Post subject: |
hows it run.. you sure they are adjusting right ..probably wore out then
-nick Guest
Posted: Sun Jan 20, 2002 12:40 pm Post subject: |
if you've just replaced the cam then it's not surprising that at least one adjusting screw will need to be replaced with a larger or smaller one (dealer parts). that's why there are different screws to begin with.
also, have you had the cam checked out? having shiny lobes and not having too much wear don't neccesarily coincide.
good luck,
-nick |
badenkb Guest
Posted: Mon Jan 21, 2002 7:12 am Post subject: |
Hi all
Thanks for the info, I did manage to reset the clearances after some judicious exchaning of adjustment screws - shame the car still won;t start though!!! (see long thread earlier on this problem!!)
Ian |
