Paul T. Guest
Posted: Thu Jan 17, 2002 2:15 am Post subject: |
When you put that Franco Cam gear on your engine, could you still put the timing belt cover on?
wdb Guest
TonyMechanic Guest
Posted: Thu Jan 17, 2002 10:56 am Post subject: |
| Who needs the cover anyway? It just added weight! |
Patrick Guest
Posted: Fri Jan 18, 2002 1:16 am Post subject: |
If you have a 931, please use the cover!
Have you ever seen what happens to an interference engine when the belt jumps or breaks?
Without the cover a small stone can make the belt jump...
L8ta
Patrick
TonyMechanic Guest
Posted: Fri Jan 18, 2002 1:32 am Post subject: |
| GOOD point! I hadn't thought of that! and yes, I've seen all too many motors blow after a bad timing belt, if your lucky, it'll only be the top end! Your a smart man Patrick. |
AppleBit
Joined: 16 Nov 2002 Posts: 1516 Location: Minneapolis, MN
Paul T. Guest
Posted: Tue Jan 22, 2002 6:12 am Post subject: |
I'm considering getting one for my 924. Is there anything special that needs to done once this device is added to the cam?
AppleBit
Posted: Wed Jan 23, 2002 3:38 am Post subject: |
Yes, to get full use of the sprocket you should have one of two options done.
1. (cheap - about $50 - $75) get your timing curve changed. You have to choose where you want your power to come in and stuff
2. (not so cheap - $600 + $125) $600 for electromotive distributorless ignition system and $125 (about) to fabricate the wheel to the crank. This is by far the best way to get the most horsepower, excellent starts on cold and warm engines, better fuel economy... I could go on and on...
Yes, I recommend option 2. On a stock engine with DIS and the franco cam gear the power difference is great enough that you _WILL_ drop your jaw... Then you add a cam like WebCam's Stage 1 camshaft and you freak out with how much quicker the car is.... |
yOnKiNaToR Guest
Posted: Mon Mar 25, 2002 1:06 pm Post subject: |
do they make them camshafts and cam gears for the 924S by any chance?
AppleBit
Posted: Tue Mar 26, 2002 3:20 am Post subject: |
| Only the 2.0 liter engines.... |
