lighter flywheel
swicks
Guest
PostPosted: Sun Dec 09, 2001 6:38 am    Post subject: Reply with quote
I want to lighten my flywheel. has anybody worked out the ideal weight, the car will be used for occasional track use and is my daily car.
cheers
steve
PostPosted: Sun Dec 09, 2001 8:14 am    Post subject: Reply with quote
The ideal weight is the least amount you can still drive the car with (as a driver, reflecting on your skill).
Not sure about the minimum thickness. I've heard of people taking nearly half the thickness away - just have the machinist remove the dowel pins (that locate the pressure plate) before surfacing, and remove material across the full face of the flywheel, not just where the clutch disc makes contact...
Rick MacLaren
Guest
PostPosted: Wed Jan 09, 2002 6:46 am    Post subject: Reply with quote
You took off 1/10th of an inch, didn't you Vaughan?
Anyways, that's what I took off mine. It's also being balanced along with the clutch, pistons, rods, crank, etc.
Peter
Guest
PostPosted: Wed Jan 09, 2002 3:06 pm    Post subject: Reply with quote
Read the discussion about some of the pros/cons of lightening your flywheel:
http://shoptalkforums.com/bbs/NonCGI/Forum1/HTML/001593.html
-Peter A. Holiat
AppleBit
PostPosted: Sat Jan 12, 2002 6:46 am    Post subject: Reply with quote
the 924 flywheel is 18 lbs stock.
You can safely lighten it to about 15 lbs before the flywheel strength becomes a question.
- Jon
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
data
Guest
PostPosted: Mon Jan 14, 2002 3:01 pm    Post subject: Reply with quote
You have to lighten the flywheel from the back not from the clutch surface side. I had mine on a 924 down to 10.5 lbs with good reliability. Make sure to balance pressure plate with it.
