Right hand drive 924 in the US?
TonyMechanic
Guest
PostPosted: Thu Jan 10, 2002 1:49 am    Post subject: Reply with quote
Does anyone out there have a right hand drive 924? I was just curious how they were different (other than the obvious) and if they handled as well as the left hand drive 924s. Thanks
kevrl
Guest
PostPosted: Thu Jan 10, 2002 7:10 am    Post subject: Reply with quote
Mine's a Right Hand Drive 931, they are all RHD here in the UK.
Brake master cylinder is on the same side for LHD and RHD cars, but on the RHD the pedal is linked to the servo by a cross bar. The clutch cylinder is above the Exhaust manifold (header ?) and has a seperate reservoir away from the heat from the exhaust. LHD 931's take their clutch fluid from the brake fluid reservoir. I can't see that any differance in LHD to RHD in the handling aspect, steering column UJ's probebly don't last as long on RHD 'cos they are close to the hot exhaust.
Kevin
(931 - almost intercooled)
