mdaniel83 Guest
Posted: Fri Dec 28, 2001 11:44 am Post subject: |
Hi everybody! I have just fixed and got my car to run again after 5 months of sitting in the back yard, but the problem is that my turn signals and horn don't work anymore, the flashing light on the dash that suppose to flash after you click to turn - well it's on but it doesn't flash. and btw when I press the brake, my brake light doesn't go on either...
thanx in advance
Dan |
larso Guest
Posted: Fri Dec 28, 2001 2:20 pm Post subject: |
| a ground or a short, it's multimeter time. |
RobE Guest
Posted: Sat Dec 29, 2001 2:33 am Post subject: |
| Burned out light bulb???? |
dpw928 Guest
Posted: Sat Dec 29, 2001 2:49 am Post subject: |
After sitting that long your lamps are probably crudded. Take them all out and clean the contacts. The rears are the most likely culprits since the brakelights are involved.
Dennis |
SpiNko Guest
Posted: Sat Dec 29, 2001 4:25 am Post subject: |
anybody suggest fuses? I once spent a whole day trouble shooting a faulty headlight motor (had to replace it once before) and after much work, my girlfriends little brother asked if I had checked the fuse, guess what, it was the fuse! DOOHH!!!
Its not my fault im Canadian!
[ This Message was edited by: SpiNko on 2001-12-29 05:26 ] |
mdaniel83 Guest
Posted: Sat Dec 29, 2001 10:35 am Post subject: |
HI ALL...
well i haven't checked the fuses yet, but what i do know is that all the lamps work, it's just not flashing when I turn the turn signals on....any other ideas? |
afenn Guest
Posted: Sat Dec 29, 2001 12:24 pm Post subject: |
Replace the flasher located under the dash, you can get it at Autozone for about ten dollars.
[ This Message was edited by: afenn on 2001-12-30 08:07 ] |
Roger Hall Guest
Posted: Sat Jan 05, 2002 2:00 pm Post subject: |
| there are relays above the fuse panel. Sounds like they might be bad. You can jump the contacts to see if its the relays or the wiring. Also check the ground for the whole pannel of fuses and relays |
mdaniel83 Guest
Posted: Fri Jan 18, 2002 6:50 am Post subject: |
Thanx Afenn, it was a flasher relay...now my horn and turn signals are working...
now i just have to get my brake lights to work...which is who knows how...
btw does anyone has a fuel pump relay kicking around? its too F@#king expensive in dillership here in Winnipeg. |
Mannghi Guest
Posted: Sat Jan 19, 2002 12:45 pm Post subject: |
About the brake lights, check that the ground connections back by the rear clusters are good and the connection is tight. Also check that the sockets in the clusters are tight and free from corrosion.
numbers Guest
Posted: Wed Jan 23, 2002 8:20 am Post subject: |
| My brake lights quite last year, and it was the pressure switch. |
mdaniel83 Guest
Posted: Wed Jan 23, 2002 9:22 am Post subject: |
| pressure switch? explain... |
Posted: Thu Jan 24, 2002 12:23 am Post subject: |
The BLS (brake light switch) on these cars is in the MC in the form of a pressure switch, not a switch on the brake pedal like the 944 and other cars. Look at the electrical connections on the MC. They often break or get corroded.
numbers Guest
Posted: Thu Jan 24, 2002 8:27 am Post subject: |
| The pressure switch is located on the side of the master cylinder. It just screws into place. Mine has two wires going to it. To check it, have someone apply the breaks while you check for continuity accross the switch. |
