Blas Costagli Guest
Posted: Sun Dec 16, 2001 12:37 pm Post subject: |
| Anyone out there experiment with the Split-fire sparkplugs? What plug number should I use and should I use the stock gap on my 1979 924? Thanks... |
awilson40 Guest
Posted: Sun Dec 16, 2001 1:19 pm Post subject: |
I tried them once in my car and was unimpressed. They didnt improve anything and didnt burn as clean. Tooke em out and threw em away. I like NGK 'hot U' plugs.
Mannghi Guest
Posted: Sun Dec 16, 2001 5:05 pm Post subject: |
I've never heard anyone reliable say anything good about SplitFire plugs, you're better off with stock Bosch, you could go platinum or +4 if you want to spend the dough.
Vince Ponz Guest
Posted: Mon Dec 17, 2001 6:34 am Post subject: |
| Used them and they wore out quickly. No difference in performance. |
AppleBit
Posted: Tue Dec 18, 2001 1:39 am Post subject: |
NGK are the best for the 924.
Bosch are also very good.
Platinum is not for power, but for longevity...
- Jon |
eturbo924 Guest
Posted: Tue Dec 18, 2001 2:08 am Post subject: |
Split fires did not seem to make any difference. Now using NGK.. the 4 tip Bosch is not available for 924. Rapid fires seemed to work well though.
Eric |
Vince Ponz Guest
Posted: Tue Dec 18, 2001 7:48 am Post subject: |
| test |
larso Guest
Posted: Tue Dec 18, 2001 2:46 pm Post subject: |
they all suck hairy bum.
Don't bother with them.
Silver plugs are the best, except they may not last as long, and they don't work with aftermarket ignitions, and im not sure if they work with turbos.
I had a post on this a while ago about it, son't feel like going over it again  |
Blas Costagli Guest
Posted: Tue Dec 25, 2001 5:23 am Post subject: |
| Thanks all..... |
