Which car to buy?
Posted: Sun Nov 23, 2003 8:06 pm Post subject: How much do you save by going to body kits? |
Removing the steel bodies and putting on fiberglass in it's place. Hood, fenders and doors too. How much can you really save? 100 lbs? 200? How much weight can you drop if you do the interior too? Have a couple of sport seats, carpet stays, sound insulation goes out along with the radio, speakers and tape console. I would want it to look like a normal car{ ie keep the carpet} Anyone have weights of these parts? If I toss the rear seat, what can go in it's place? I don't want it to look weird. |
Vince Ponz
Posted: Mon Nov 24, 2003 1:28 am Post subject: |
stock seat to race 30 to 10-20
rugs and insulation 40
interior parts 7
rear seat and back 20
rear mat and insulation 10
front and rear bumpers to Euro mounts 3.5 -8oz
US rubbers ea 3 lbs to Euro rubber about 4 oz ea for large 2 small
bumpers 25 to 11-12
Go on a diet lose 50 lbs _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Kenodog
Posted: Mon Nov 24, 2003 4:46 am Post subject: |
Getting a fibreglass hood saves around 25
cutting down bumper shocks or making new brackets out of aluminum saves 20
rear hatch glass to Lexan 40-50
remove AC and all peripherals 75-80
Aluminum rad from an early 944,racing seats,plastic gas tank from a 944 etc. The list of possibilities is endless.For $3000 and some shopping around I think you could get it down to a respectable 2100-2200 lbs. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Dez
Joined: 25 Jul 2003 Posts: 189 Location: Wokingham, UK
Posted: Tue Nov 25, 2003 10:18 pm Post subject: |
Vince,
Do you have anymore pics of that fine car of yours? _________________ 1982 Porsche nine two four with Carrera GT conversion - people think i'm slow cos it's an X plate!!
http://www.p-caronline.com/directory/dez |
CBass
Posted: Tue Nov 25, 2003 11:05 pm Post subject: |
There is weight to be saved elsewhere too, converting the headlights to fixed buckets, converting to a coilover in the rear, with a Kokeln style rear crossmember.
Vince, how do you figure the rear mat is 10 lbs? Maybe your car had a lighter one than mine, but it weighed at least 30-40lbs.
GT Racing claims that you can drop about 50 lbs by converting to fiberglass bumpers. Their fenders weigh 4 lbs each unpainted, so that has to be quite lighter than stock, anyone know offhand how much a 924 fender or 1/4 panel weighs? They also claim a stock hood is 80 lbs, but I don't think it is. Before I replaced my hood hinges, I had to lift that hood on and off several times a week, and it's no 80 lbs.
http://www.gt-racing.com/catalog/gtr944.htm
People have weighed their sound deadening after removing, it's between 70-80lbs, IIRC. The bottom half of the rear seats don't really weigh anything, all the weight is in the top half. I put in new seats from a Mazda RX7, and they weigh about 20 lbs each, vs 35 or so for the highbacks, so that drops 30 lbs right there.
My goal is to get down to around 2100 lbs with a full interior, full glass and metal fenders. This involves swapping in an engine that is 80lbs lighter, making new suspension arms from tubular aluminum, and everything mentioned above. _________________ '81 931 in various states of assembly |
Neil924
Posted: Tue Nov 25, 2003 11:19 pm Post subject: |
It says you save about 27 lbs per fender. |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Wed Nov 26, 2003 4:01 pm Post subject: |
the fiberglass fenders weigh almost nothing. A 4 year old could have lifted them. The stock fenders are about 25 lbs each. Substantial difference, and you get to have bigger wheels/tires. _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
OR_Sunset
Posted: Wed Nov 26, 2003 7:13 pm Post subject: |
Okay, so if we can get a definitive figure like "a body kit (fenders, bumpers, 1/4 panels, rocker panels, headlight buckets) saves X lbs. weight"
can we then get $XXXX gets you 0.XX sec. faster 0-60 or ET times?
What is the dollars to decimals relationship here? |
Neil924
Posted: Wed Nov 26, 2003 7:48 pm Post subject: |
OR_Sunset wrote: | What is the dollars to decimals relationship here? |
Probably crappy. |
Posted: Thu Nov 27, 2003 3:02 am Post subject: |
why dont you weight it, then convert and weight and find out. _________________ 3 928s, |
ryoji
Posted: Thu Nov 27, 2003 3:23 am Post subject: |
Last time when I estimated for non-metal body parts; $8.5 per lb save, with least expensive sellers. With shipping and some instration parts etc, I think it could go up to $10 per lb. I think you get close to 8hp per 100+lb, isn't it? _________________ R.I.P.:a 924 ITA race car |
