d12-Matt Guest
Posted: Mon Nov 26, 2001 12:42 pm Post subject: |
| I found out today that the red wires are supposed to go to ground and the black ones go to the positive connections on the starter motor. In the process I seem to have damaged the alternator. Are all the wires on 924's backwards like that? Also, what's a good price for a remanufactured alternator? |
Diesel Guest
Posted: Mon Nov 26, 2001 1:23 pm Post subject: |
I've got a good one, e-mail me if you want it.
924_fan Guest
Posted: Tue Nov 27, 2001 6:34 am Post subject: |
According to the wiring diagram:
The red leads go from starter terminal 30 to B+ on the alternator. Terminal 30 is directly connected to the + terminal on the battery. The alternator case and the starter case are grounded.
d12-Matt Guest
Posted: Tue Nov 27, 2001 8:18 am Post subject: |
| You mean that one terminal has both a red wire and a black wire leading to it? |
924_fan Guest
Posted: Tue Nov 27, 2001 1:26 pm Post subject: |
This description may get confusing as it is far easier to look at a wiring diagram for the info.
Starter terminal 30 is the large terminal that connects to the battery (the large positive battery cable). The alternator is using this as a "direct" connection to the battery.
Starter terminal 16 has a black wire going to the ignition (with a resistor in line). This supplies power to the ignition when the starter is engaged.
Starter terminal 50 has a red/black wire that eventually connects to the start position on the ignition switch.
The alternator has 3 connections:
B+ to the battery via the starter.
D+ eventually gets to the alternator light in the instrument panel.
And the ground wire connecting to the engine block.
Alternator D+, Starter 50, and Alternator 16 all use a three conductor Amp connector that sits on the right side by the firewall.
Usually, Porsche ground wires are brown.
d12-Matt Guest
Posted: Tue Nov 27, 2001 2:54 pm Post subject: |
| Hey thanks. I just tried setting up all the wires like that and the alternator mysteriously came back to life. Lesson learned: I shouldn't just connect wires where I think they ought to go, because chances are I'm wrong. |
wdb Guest
Posted: Sat Dec 15, 2001 3:40 pm Post subject: |
| I got a bid from a auto electric shop ,for $80 they would rebuid mine. |
