Same question from "Interior" re: vinyl color
D Hook
Guest
PostPosted: Thu Dec 13, 2001 10:02 pm    Post subject: Reply with quote
I've posted the same question on the "Interior" section but I need to find out the answer ASAP.
Does anyone know if the brown color used in the early 924's matches the color of the vinyl used in the mid-80's 944? I'm looking at buying some interior pieces for my car and can't tell by the picture if the color will match what I already have. Did Porsche change the color brown or is brown is brown is brown....regardless of the vehicle model and year?
Thanks
teo
PostPosted: Thu Dec 13, 2001 10:08 pm    Post subject: Reply with quote
Try to check the color codes of the cars, if you can.
They might be different for the cars, but then you can still check thier names.
I'm not sure if it works, but at least it is some starting point.
numbers
Guest
PostPosted: Fri Dec 14, 2001 7:05 am    Post subject: Reply with quote
I bought an brown interior door pull off of Ebay and it was a darker shade than the ones on my '80 931.
D Hook
Guest
PostPosted: Fri Dec 14, 2001 10:49 am    Post subject: Reply with quote
Yeah, that's what I thought. The picture looks darker than what I have. It's out of a 944, early model, and looks too dark to match up.
Thanks for the input.
