d12-Matt Guest
Posted: Fri Nov 09, 2001 1:37 pm Post subject: |
My cold idle speed is around 200 RPM, and it often stalls when coming back down after I rev the engine. It runs fine once the engine has warmed up, though. I think the problem is the auxilary air regulator. I put it in the freezer for a couple hours, but it only opened up about 1/8th of the way. Should I replace this part, or should I look for something else first?
The car is a 1977 924 US version, if it makes any difference. |
924Kid Guest
Posted: Fri Nov 09, 2001 4:13 pm Post subject: |
ditto on d-12's question!!
larso Guest
Posted: Sat Nov 10, 2001 11:22 am Post subject: |
sounds like it's the problem
If giving the car gas helps, that's what the aux air valve does exactly. |
d12-Matt Guest
Posted: Sat Nov 10, 2001 12:07 pm Post subject: |
| Yeah, giving it gas does fix it. At first I just adjusted the idle speed screw so it ran properly when cold, but then once the engine warmed up it would idle at like 1500 RPM. |
larso Guest
Posted: Sat Nov 10, 2001 12:12 pm Post subject: |
Exactly...definately sounds like the aux air valve. If you decide to buy a new one, let me know, i can get stuff wholesale.
I've got a used one too, I might keep it as a spare though are you looking for new or used do ya think? |
d12-Matt Guest
Posted: Sun Nov 11, 2001 7:48 am Post subject: |
I was just about to call a porsche dealership to see how much it would cost there. I think I want a new one, as long as it's not too expensive. How much would it cost from the wholesaler?
Scratch that. I think I may have figured out how to adjust the one I currently have so it is open at the right temperature.
[ This Message was edited by: d12-Matt on 2001-11-11 14:32 ] |
924Kid Guest
Posted: Wed Dec 05, 2001 9:31 am Post subject: |
I feel like a retart, but where the hell is the aux. air valve??
d12-Matt Guest
SilverArrows Guest
Posted: Wed Dec 05, 2001 3:21 pm Post subject: |
I had no idea either 924kid! "Damnit Jim I'm a doctor not a mechanic."
By the way, d12-Matt has now adjusted/fixed the idle rpm. |
924Kid Guest
Posted: Wed Dec 05, 2001 4:00 pm Post subject: |
I thought that was it!! I always wimp out before I take anything apart on this car, needed to make sure. Thank you much guys.
numbers Guest
Posted: Thu Dec 06, 2001 7:21 am Post subject: |
| So, how did you adjust it? |
d12-Matt Guest
Posted: Thu Dec 06, 2001 8:26 am Post subject: |
| There is a little bolt that can slide a bit when you loosen the nut. Moving it away from the center makes the hole open more. Also the bi-metallic strip is connected directly to the plastic electrical plug, so if that plastic part isn't flush with the metal then the hole probably won't open all the way. I just wrapped some thread in the groove to make it fit better. Plus, there was some grit inside that was preventing the piece from rotating freely, so I ground the rivets and took everything apart to clean it. |
