teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Sat Nov 24, 2001 3:49 am Post subject: |
Hey guys,
I just did some calculations on the different types of 924 transmissions, speed as a function of engine rpm - wheel size - gear ratios.
There are some interesting results, and if the calculations are right and the type 016Z is the one also known as the "snailshell", now I know why everyone likes them.
Would you check it and tell me if I made some mistake in it?
http://web.matavnet.hu/teoinfo/p924/transmission.htm
Teo
[ This Message was edited by: teo on 2001-11-24 04:51 ] |
teo
Posted: Sat Nov 24, 2001 7:05 pm Post subject: |
Hmm, so I couldn't get it right for first time, now it's fixed.
Teo |
cs Guest
Posted: Sat Nov 24, 2001 7:07 pm Post subject: |
nevermind, i see you've already figured it out.
engine rpm/(gear ratio*axle ratio)= wheel rpm
wheel rpm*circumfrence of tire=ft/min
ft/min * 60/5280= miles/hour
example: numbers are just estimates of what i remember, in first gear at 6000 rpm
6000/14=428.571
428.571*6=2571.43
2571.43*60/5280=29.2208mph
[ This Message was edited by: cs on 2001-11-24 20:08 ] |
Joes924 Guest
Posted: Sun Nov 25, 2001 4:25 am Post subject: |
Thats pretty impressive kind of ..
larso Guest
Posted: Mon Nov 26, 2001 4:35 pm Post subject: |
| The turbo snailshell is the only tranny that makes the 931 look fast on paper, since it goes to 60 with the old rev limiter in second.... |
Joined: 29 Jul 2001 Posts: 9081 Location: Royal Oak, MI, USA
Posted: Tue Nov 27, 2001 2:54 am Post subject: |
I hate to break your heart, but Jon did this a while ago in a spreadsheet:
http://www.924.org/Downloads/Downloads.htm
It's the one labeled tranny ratios...
teo
Posted: Tue Nov 27, 2001 4:07 am Post subject: |
No problem, a few minutes ago I've even found it on my HDD saved from the site
So, before I start doing something I should check:
1: http://www.924.org
2: my own computer
3: the entire internet (I've found quite a few sites with rpm/speed calculators, of course only after I've done mine)
Anyway, I'm just learning this automotive stuff, and a little excerise will not hurt... even if it's only the theoretical side.
Teo |
