924 shop manual
larso
Guest
PostPosted: Sun Nov 25, 2001 7:47 am    Post subject: Reply with quote
What all does the shop 924 manual have in it? I have seen the 931 manual, but not the 924 manual. Does it have more specific wiring diagrams in it? Such as it showing the closed circuits that the haynes doesn't...inside relays, circuit boards, etc.?
PostPosted: Tue Nov 27, 2001 2:46 am    Post subject: Reply with quote
No, no more specific than the 931 manual. It's the same kind of stuff as the 931 manual, just more of it...
Guest
PostPosted: Thu Dec 20, 2001 11:31 am    Post subject: Reply with quote
If you have a 924 "NA", then the 924 Workshop Manual is all that's needed. If you have a 931, then you should have the 924 Workshop Manual plus the 924 Turbo Workshop Manual.
"The 924 turbo workshop manual only describes repair operations that differ from those for 924 models. Refer to the 924 workshop manual for all other information."
numbers
Guest
PostPosted: Sat Dec 22, 2001 1:37 am    Post subject: Reply with quote
I have access to detailed wiring diagrams for all Porsches up to 1990. If you get in a great need let me know and I will see if I can get reproductions at a reasonable price.
larso
Guest
PostPosted: Sun Dec 23, 2001 1:08 pm    Post subject: Reply with quote
The 931 manual I found really vague, numbers email me direct...
I would like to see stuff like diode part numbers and detailed circuit info, the reason being because all the part numbers on the internals of these circuits are from the 1980s and sometimes it is hard to cross-referance them at my component stores. Ive got some ancient radioshack books that show cross references, but sometimes the parts inside burn up or get discolored and you can't tell what the part is. So if the manuals go into this detail I would be interested for sure.
numbers
Guest
PostPosted: Tue Dec 25, 2001 3:38 am    Post subject: Reply with quote
It will be a few days before I can get access to the diagrams. Then I will see how much detail they include and let you know.
