Mannghi Guest
Posted: Sat Nov 24, 2001 1:44 pm Post subject: |
So, what makes the euro engine produce more horses than the same year US engine? The difference betweeen 95hp and 125hp is kind of a kick in the teeth for us Yanks.o
Guest
Posted: Sat Nov 24, 2001 10:49 pm Post subject: |
| The difference is the compression ratio 8.0:1 vs 9.3:1. I belive the emissions control was the reason for the lower ratio in the US. |
dwak Guest
Posted: Sun Nov 25, 2001 4:17 am Post subject: |
And exactly how did they change the copression ratio. Head gaskets and pistons?
Posted: Sun Nov 25, 2001 10:22 pm Post subject: |
| the emission gear was different. The Aus/UK cars and probably all cars not destined for Nth America/Japan were tuned for leaded fuel - more advance, no cat. and they were lighter too with fibreglass bumpers. |
larso Guest
Posted: Mon Nov 26, 2001 5:26 am Post subject: |
| different ignition distributors (calibrated different) and pistons, and no emmisions, are probably the main thing. If you look at the curves in the haynes for the ignitions, I belive one of the old US 924s has a good curve, so it's a good tuning trick bolt on. |
Diesel Guest
Posted: Mon Nov 26, 2001 5:53 am Post subject: |
Anyone looking for a Euro distributor can e-mail me. I've got one from a 79.
Mannghi Guest
Posted: Mon Nov 26, 2001 2:25 pm Post subject: |
I have a '77 which I belive is the dizzy with more advance.(source AppleBit's web site) It would be the only advantage that year has though. Its all good though.l
Ants Guest
Posted: Tue Nov 27, 2001 2:39 am Post subject: |
Yeah its the compression ratio and Cat, fortunately we didn't have to have Cats and so could develop more power, Turbo's even more so.
Ants
Joined: 29 Jul 2001 Posts: 9071 Location: Royal Oak, MI, USA
Posted: Tue Nov 27, 2001 2:49 am Post subject: |
Think again about the distributors; sure, the curves are different, but mainly just in when you get full advance - comes in quicker in the Euro. You still get the same amount of total advance from the advance mechanism.
Just advance your static/base/idle advance setting. Problem solved. Also consider that once you get to 2000-2500RPM you're at full advance anyway.
