What makes a Euro engine?
Mannghi
PostPosted: Sat Nov 24, 2001 1:44 pm    Post subject: Reply with quote
So, what makes the euro engine produce more horses than the same year US engine? The difference betweeen 95hp and 125hp is kind of a kick in the teeth for us Yanks.o
PostPosted: Sat Nov 24, 2001 10:49 pm    Post subject: Reply with quote
The difference is the compression ratio 8.0:1 vs 9.3:1. I belive the emissions control was the reason for the lower ratio in the US.
dwak
PostPosted: Sun Nov 25, 2001 4:17 am    Post subject: Reply with quote
And exactly how did they change the copression ratio. Head gaskets and pistons?
PostPosted: Sun Nov 25, 2001 10:22 pm    Post subject: Reply with quote
the emission gear was different. The Aus/UK cars and probably all cars not destined for Nth America/Japan were tuned for leaded fuel - more advance, no cat. and they were lighter too with fibreglass bumpers.
larso
PostPosted: Mon Nov 26, 2001 5:26 am    Post subject: Reply with quote
different ignition distributors (calibrated different) and pistons, and no emmisions, are probably the main thing. If you look at the curves in the haynes for the ignitions, I belive one of the old US 924s has a good curve, so it's a good tuning trick bolt on.
Diesel
PostPosted: Mon Nov 26, 2001 5:53 am    Post subject: Reply with quote
Anyone looking for a Euro distributor can e-mail me. I've got one from a 79.
Mannghi
PostPosted: Mon Nov 26, 2001 2:25 pm    Post subject: Reply with quote
I have a '77 which I belive is the dizzy with more advance.(source AppleBit's web site) It would be the only advantage that year has though. Its all good though.l
Ants
PostPosted: Tue Nov 27, 2001 2:39 am    Post subject: Reply with quote
Yeah its the compression ratio and Cat, fortunately we didn't have to have Cats and so could develop more power, Turbo's even more so.
Ants
PostPosted: Tue Nov 27, 2001 2:49 am    Post subject: Reply with quote
Think again about the distributors; sure, the curves are different, but mainly just in when you get full advance - comes in quicker in the Euro. You still get the same amount of total advance from the advance mechanism.
Just advance your static/base/idle advance setting. Problem solved. Also consider that once you get to 2000-2500RPM you're at full advance anyway.
