yOnKiNaToR Guest
Posted: Tue Nov 06, 2001 2:30 pm Post subject: |
i've recently bought my car and i just realized that i have a white sludge substance in the coolant tank and on the coolant tank cap. what is this caused by?
also, i have a leak of green fluid (antifreeze i believe)that leaks down through the skidplate. someone told me it could be the water pump with that pulley connected to it and that if the water pump seizes, it could cause the timing belt (which i assume is connected to that pulley), to slip off and bend valves...is this true and what else could cause the leak and how should i go about fixing it? (17 years old and don't know mechanics very well)
kaffine krazed Guest
Posted: Tue Nov 06, 2001 5:17 pm Post subject: |
| What year and model is your car? |
yOnKiNaToR Guest
Posted: Wed Nov 07, 2001 6:50 am Post subject: |
| an '88 924S |
yOnKiNaToR Guest
Posted: Wed Nov 07, 2001 8:47 am Post subject: |
| a few minutes ago i took off the skidplate and over most of the bottom end of the engine is oil dripping off ends and over stuff..i checked the oil and it's at maximum..for the last day, i haven't leaked anything...very weird. |
Posted: Wed Nov 07, 2001 8:52 am Post subject: |
Sounds rather like you're due for waterpump, belts, rollers, and seals. Check under the 944 resources, it's the same engine. Do it now, as the oil on the belts can also degrade them and cause them to snap, end result same as the waterpump seizing, it'll trash the head.
Sounds like the PO didn't have the car properly maintained.
yOnKiNaToR Guest
Posted: Wed Nov 07, 2001 9:35 am Post subject: |
| but the belts are completey dry and the oil doesn't seem to get to the belts.i know hardly anything about cars so i'll take it to jiffy lube or some other place and get a tune and up and see if they can do that stuff i guess. :/ |
924Kid Guest
Posted: Wed Nov 07, 2001 10:21 am Post subject: |
Hey, aren't all you guys forgetting that he has a Honda engine in that thing. Why don't you just take it to a Honda service place/dealer? I also own a Honda on top of my Porsche, and obviously it's very reliable, your motor shouldn't be leaking or anything. It must be a problem with the engine swap itself.
yOnKiNaToR Guest
Posted: Wed Nov 07, 2001 12:00 pm Post subject: |
haha... real funny..well my car with the "honda" engine could beat yours so i wouldn't talk.  |
924Kid Guest
Posted: Wed Nov 07, 2001 3:55 pm Post subject: |
Um, k....I wasn't making fun of you, I was just trying to help. I have no problem with you having a Honda engine, like I said, I also own a Honda. Not the most exciting car, but a good one. And I never said anything about my car being faster than yours, just giving advice because I noticed ALL of the other replies you got treated your car as if it had the original engine, which might make them pointless and lead you in the wrong direction wouldn't it!?!!
1979 Diamond Silver Met. Porsche 924 CA. spec
("Dude, you're rich, you got a Porsche! No, I'm not....so chill already!!")
[ This Message was edited by: 924Kid on 2001-11-07 16:59 ] |
yOnKiNaToR Guest
Posted: Thu Nov 08, 2001 1:57 pm Post subject: |
| hey man..i don't know what your talking about with this honda thing...it does have the original 924S engine. |
924Kid Guest
Posted: Thu Nov 08, 2001 2:10 pm Post subject: |
dude, then something is up with your pics. clearly shows honda
larso Guest
Posted: Thu Nov 08, 2001 4:30 pm Post subject: |
This is terribly funny. Could someone direct me to the pictures? I didn't see a link for pics.
Lars |
yOnKiNaToR Guest
Joes924 Guest
Posted: Fri Nov 09, 2001 4:28 pm Post subject: |
| Theres record breaking sadness that overtakes me as I think of the idea.. Hey lets put a Honda mo in this por-sche :sick: |
