Johnny_924S Guest
Posted: Fri Nov 02, 2001 1:52 am Post subject: |
| hey hey its me again, well the car is running and quite well i might add, but ive noticed that when i shift from 2nd to 3rd and somethimes from 3rd to 4th i feel and hear a king of quiet clunk sounds like its comming from the rear end, it only does it sometimes and it is quiet, also it rarly does it on the downshift, like i said i just got it running after it sat for nearly 3 years so would a fluid change help or is this more serious.....thanks johnny |
Diesel Guest
Posted: Fri Nov 02, 2001 2:31 am Post subject: |
Could be a CV joint too.
Johnny_924S Guest
Posted: Fri Nov 02, 2001 4:09 am Post subject: |
| is there any way to tell (an easy check) if it was the cv joint, how come it only does it in certain gears? |
cs Guest
Posted: Fri Nov 02, 2001 4:26 am Post subject: |
| does it do it right when the clutch engages. does it do it if you're real easy letting off the clutch. you can try jacking up the rear end and while holding on to the inner cv joint, spin the wheel to see how much play is in the joints |
Diesel Guest
Posted: Fri Nov 02, 2001 5:43 am Post subject: |
I had a similar noise recently and I couldn't tell where it was coming from. Dumb luck got me to the CV joint. I was replacing the boots and repacking the joints and I found one joint's ball bearings were galled. Noise gone after I got a new one. By the way, cheapest I found was at Vertex($55). A good one too(Lobro). Odd because they are usually expensive.
Diesel Guest
Posted: Fri Nov 02, 2001 5:49 am Post subject: |
Pretty good web-site you've got, Johnny. Laughed my nuts off.
Johnny_924S Guest
Posted: Fri Nov 02, 2001 7:24 am Post subject: |
| hey glad you enjoy the site, it hasnt been updated in a while but its comming along. about the noise from the rear end, if i am really gentle releasing the clutch it will not make the noise. i dont think it makes noise when i depress the clutch but it does sound as if the whole shift liinkage is a bit noisy. like i said it isnt too bad but it is one of those things that really freakes me out espicially since it is my first time driving it.. im lead to elieve that it is my cv joint but anyone out there who has encountered a sisilar problem let me know, much appreciated....johnny |
John Mueller Guest
Posted: Sat Nov 03, 2001 7:08 am Post subject: |
I am having the same problem right now. My guess at this point is that you are hearing the suspension arms moving. I am going to check all my bushings and mounts this weekend and I will let you know if that is truly the source of my clunk. My CV's are new/rebuilt so I know they are ok.
