1982-924NA 'popping' on decell
awilson40
Guest
PostPosted: Thu Oct 25, 2001 11:19 am    Post subject: Reply with quote
After adding a free flowing exhaust, I get a pit of popping when decelling, downshifting and, sometimes, when briskly upshifting. Mixture seems fine and all 'lambda' circuits are functioning. Is this normal when changing exhaust?
Thanks
PostPosted: Thu Oct 25, 2001 12:03 pm    Post subject: Reply with quote
Not uncommon... I've got quite a bit of popping, with my MSDS header, 2.5" pipe, and single bullet (through-flow glasspack-style) muffler.
jamez
Guest
PostPosted: Thu Oct 25, 2001 1:24 pm    Post subject: Reply with quote
mine does the same thing too...
bacook
Guest
PostPosted: Thu Oct 25, 2001 11:03 pm    Post subject: Reply with quote
It can look really cool as well! Porsche better get their act together if they plan to ever beat these GTRs!
http://www.fastdetails.com/alms/pics/spBMW43Airwa8.jpg
Zuffen
PostPosted: Thu Oct 25, 2001 11:30 pm    Post subject: Reply with quote
Common problem it seems as I have it at times after a hard run. I wonder if the decel valve is loosing effectiveness.
Bob Dodd - 924turbo@cox.net
awilson40
Guest
PostPosted: Fri Oct 26, 2001 2:52 am    Post subject: Reply with quote
Thanks guys.
BTW... I removed the Decell valve on mine. It was working properly, but I saw no difference with it on. The plastic port on the intake that the decell went to had broken off so I just plugged it and removed the decell valve.
eturbo924
Guest
PostPosted: Fri Oct 26, 2001 9:32 pm    Post subject: Reply with quote
How is the car running otherwise? How is it under part throttle? Mine was acting similary until I retarded the timing just a bit. Seems I had it set to agressively. Not sure where it is at the moment. It is being painted at the moment. Anyway try a bit less advance and see what happens. Helped mine. I have bursh header and 2.5 inch exhaust. You can see my system on my site under my projects.
Eric
awilson40
Guest
PostPosted: Sat Oct 27, 2001 6:01 am    Post subject: Reply with quote
Thanks, good idea. I might retard the timing a bit. I think I'm running a few degrees advance over spec. It runs great otherwise, no hesitation or flat spots. It has always idled a bit rougher than I would like but not too bad.
