What is part # for throttle posit switch for '82 931?
Michael Kouridakis
PostPosted: Thu Oct 11, 2001 10:21 am    Post subject: Reply with quote
I think that I need to replace my throttle position switch but I can't find the part number. Anyone know it?
Mike
PostPosted: Fri Oct 12, 2001 2:34 am    Post subject: Reply with quote
My parts list shows a #(1 "Throttle-Valve Switch" for model M31 04 81- (1981 and on) with part # 931 606 119 01
It's a square shaped piece mounted upside-down under the throttle body with a metal plate top and a black plastic cover underneath + electrical connection.
'82 924 Turbo, Home Depot boost control, blue windshield washer fluid water injection
[ This Message was edited by: Smoothie on 2001-10-12 02:40 ]
PostPosted: Sat Oct 13, 2001 3:15 am    Post subject: Reply with quote
If the TPS isn't in too bad a condition, you might just clean the contacts. I just did this about 2 months ago. I removed the plastic cover and slipped a small piece of sandpaper between each contact, applied some pressure and moved the sandpaper around to clean off the oxidation. This may be a good thing to do anyway, but; it didn't solve the problem I was hoping to fix - my actual problem was finally fixed by cleaning the connectors to the ignition box and module. Remember to put some reference marks on the tps before removing it from the throttle body so you can reassemble it in the correct position.
