5 speed for 4 speed swap
Faust
PostPosted: Tue Oct 02, 2001 9:54 am    Post subject: Reply with quote
Well, I located the gas tank I inquired about below. It is coming out of a 5 speed car. Since the transmission will be out of the other car, I've been thinking. Aside from the transmission, what else do I have to change to transfer the 5 speed to my 4 speed, 1978 car?
924_fan
PostPosted: Tue Oct 02, 2001 10:27 am    Post subject: Reply with quote
To convert from a 4 speed to 5 speed you will need (in addition to the transaxle): the torque tube, shift linkage, and torsion bar housing. You only need the torsion bar housing if your car does not have the proper one with the arms to mount the transaxle.
PostPosted: Tue Oct 02, 2001 11:25 am    Post subject: Reply with quote
Depends; what year and model is the 5-speed from???
Faust
PostPosted: Tue Oct 02, 2001 11:29 am    Post subject: Reply with quote
The 5 speed is from a standard '81 924. No turbo.
Tom Faust
PostPosted: Tue Oct 02, 2001 11:42 am    Post subject: Reply with quote
Then, as I recall, it's a straight swap. No torque tube necessary. The spline should be the same, though as noted it can get a little tight around the gas tank. I guess the only other thing that's not often noted is the shift rod - I think it's longer for the 5-speed. Or shorter... I certainly had a problem with going from a 4speed to the 931/944 5-speed (which also required a torque tube and the right clutch, but that's another story - the shaft is larger). Naturally you'll want the better shifter and shift knob.
You won't need to mess with the rear suspension except that you'd be advised to drop it as a unit to ease installation. No torsion bar carrier swap required.
Skip's comments would be correct for his '79. However, the layout of your car is different.
924_fan
PostPosted: Tue Oct 02, 2001 12:50 pm    Post subject: Reply with quote
Oops, thanks Vaughan. When I wrote that, the Audi based 5 speed completely slipped my mind.
marky522
PostPosted: Wed Oct 03, 2001 8:56 am    Post subject: Reply with quote
i have the shift rod if you need it, i also have just about everyhthing else you will need. e-mail me
Mark
Vince Ponz
PostPosted: Thu Oct 04, 2001 11:27 am    Post subject: Reply with quote
You will need the shift bar only and it should fit without any problem. I did it and used the 5 speed shifter bar. Need a torque tube I have two.
