fuel line connections....
badenkb
Guest
PostPosted: Mon Sep 17, 2001 11:28 pm    Post subject: Reply with quote
HI
Somewhere below is athread about fuel lines... I tried to fit them this weekend, only to discover that a previous owner had bodged them. The original flexible hose that the rigid fuel line should bolt up to, had been cut and replaced with plastic hose held on by jubilee clip. So I am now also needing the flexible fuel hoses that join the fuel line to the fuel accumulator and to the fuel filter.
Does anyone have a web source (preferably the UK )which can source these new ?
Thanks
Ian
kevrl
Guest
PostPosted: Wed Sep 19, 2001 2:32 am    Post subject: Reply with quote
Hi,
In UK, people that I use are :-
http://www.clubautosport.co.uk/the_shop/index_shop.htm
http://www.lodgesports.org.uk (click on 'Online Catalogues')
also :-
http://www.porscheshop.co.uk
http://www.porsch-apart.co.uk
I've used all these, they are all pretty helpful, but some more unusual parts are not listed on the web page. Try phoning them they can usually get bits for you.
Good luck
Kevin
