shift knob
Jim-87-924S
Guest
PostPosted: Thu Aug 23, 2001 11:27 pm    Post subject: Reply with quote
Looking to replace my shift knob with a more stylish one. Momo has a nice looking carbon fiber/leather on (p/n 402-853 Combat Shift knob). Will this fit on my 924S? Does the original just pull right off? I can spin it and it feels like it just pops off, but I'm afraid to try (in case it doesn't) and I break it in the process.
Thanks,
Jim
PostPosted: Thu Aug 23, 2001 11:57 pm    Post subject: Reply with quote
Yes, the original can pull off, once you pull the clip under the shifter boot, but I'm not sure that the standard aftermarket stuff like the MOMO knobs (heh heh, he said knob!) will fit right on, as I understand they're designed to screw (heh heh) on a shaft (I have a filthy mouth!)
OK, I'll shuttup now, I recommend you give Tweeks or whomever a call...
climber924
Guest
PostPosted: Fri Aug 24, 2001 12:42 am    Post subject: Reply with quote
Yes, you can take the factory shifter off buy pulling it off. but I wanted to do the same thing to my 924s but no MOMO or any other performance shifer knob will fit the do on the 924 and 944 but not the s sorry
Alex Roy
Guest
PostPosted: Sat Sep 08, 2001 1:23 pm    Post subject: Reply with quote
I put an aftermarket shift knob on my 924. I originally didn't alter my shift "stick" at all, but I did take it out and weld a few beads and then grind down the shaft to round. You can look at the finished product at:
http://www.alexroy.net
-Alex
[ This Message was edited by: Alex Roy on 2002-04-25 06:43 ]
F924T
Guest
PostPosted: Wed Sep 12, 2001 12:28 pm    Post subject: Reply with quote
Check out this site, this is what you need...post pics when you are done.
http://www.9xauto.com/shnobs.html
Good luck
Alex Roy
Guest
PostPosted: Thu Sep 13, 2001 6:47 am    Post subject: Reply with quote
My knob is model 100605 on that page. I got it for $29.95 from a local autoparts store (called "Schmuck's"). That knob worked okay without any modification to my stick, but I eventually decided to modify the shifter stick so it would be a more perminant solution.
I also added some more to my webpage with regards to the gemballa body kit I am puting on my '79 924.
-Alex
[ This Message was edited by: Alex Roy on 2001-09-13 07:32 ]
