Strut top mount options
Raize
PostPosted: Tue Nov 25, 2025 1:42 am    Post subject: Strut top mount options Reply with quote
I am pretty sure one of my strut top bearings has seized as the steering is binding/releasing even with the front raised and it's making a horrible noise and the spring is visibly binding/unbinding as the wheel is turned.
Options:
1. Replace the bearing with another bearing.
2. Replace the bearing with the stainless version of the bearing if it exists.
3. Replace with late 944 style top mounts (not sure if possible)
4. Replace with rose joint top mounts (pretty sure none of these include seals and will be destroyed within months due to UK roads)
Anything I'm missing? Leaning towards #2 even though there will be galvanic problems.
PostPosted: Tue Nov 25, 2025 10:28 pm    Post subject: Reply with quote
Sorry, I'm missing - why not replace the entire mount? Usually the rubber's shot too and wanting replacement by that point.
Raize
PostPosted: Wed Nov 26, 2025 1:39 am    Post subject: Reply with quote
Too expensive they are like £300 a pair. I rebuilt them in 2020 with new rubber and bearing but I guess it was a crap bearing. Will see when I take it apart.
PostPosted: Wed Nov 26, 2025 3:34 am    Post subject: Reply with quote
Ouch. Yeah, that makes sense.
I shouldn't expect stainless is needed - did your selection not have grease seals?
v2rocket_aka944
PostPosted: Fri Nov 28, 2025 2:19 am    Post subject: Reply with quote
HI,
You can use the rubber insert/bearing from a 1980s Volkswagen Fox/Audi 80 in the early 924/944 strut mount housing. They are inexpensive and widely available. You can also use the rubber from a 1970s VW Super Beetle but that rubber is a little softer than the 944 came with.
I have the Fox/80 insert on my car for a few years. I did have to add a 2.5mm or so washer between the top of the "strut sleeve" and the conical washer at the top though to prevent it binding on turns.
Raize
PostPosted: Sun Dec 21, 2025 6:28 am    Post subject: Reply with quote
I don't think it did. I might not have even greased it to be honest, can't remember. That would explain a lot and I'd probably want to do both sides if that's what I find. Was not as competent back then as now by a long shot.
Raize
v2rocket_aka944 wrote:
HI,
Yeah I have the Audi 80 on one side and the Super Beetle on the other because I assumed they were the same and was in too much of a hurry to sort it out.
The whole thing's a bit of a mess.
