Bosch ignition module
Siegfrieds
PostPosted: Fri Aug 01, 2025 2:08 am    Post subject: Bosch ignition module Reply with quote
Hello,
I am looking for the schematic of the ignition module.
I searched the internet already, but so far not successful.
Who can help?
Thank you.
Siegfried
SiegfriedS
1976 924
PostPosted: Fri Aug 01, 2025 4:12 pm    Post subject: Reply with quote
I only know of one guy from this board that tried to fix and draw the 924 turbo ignition box, but i think he never finished it.
For the NA i dont remember seeing anyone doing it.
If you have trouble with the ignition, i can offer you a complete replacement system that looks very close to the original and keeps the engine bay looking very close to the original, while providing the car with modern technology.
There are now quite a few cars running my kit in Germany, they have TUV and H plate, even with this system installed.
Siegfrieds
PostPosted: Fri Aug 01, 2025 6:57 pm    Post subject: Ignition nox 924. A Reply with quote
Thank you very much for your answer and the offer. Interesting!
I figured that here or anywhere nobody really published a schematic.
Yes substitution is ok, but I am an engineer and I am trying hard to repair that piece.
I did not find your ignition boxin your homepage. Please help.
Regards and good luck Siegfried
SiegfriedS
1976 924
PostPosted: Sat Aug 02, 2025 6:34 pm    Post subject: Reply with quote
https://the924.com/?page3
I offer a complete conversion that looks very close to the original equipment.
Siegfrieds
PostPosted: Sat Aug 02, 2025 7:25 pm    Post subject: Schematic for the 924 NA ignition box Reply with quote
Thank you.
I dont want to rebuild everything from scratch. I went thru the tidious job and rebuilt all components of my old Kjet.
The ignition box should be an easy task at last ….even without a schematic .
I do not surrender, 😄not yet
SiegfriedS
1976 924
gtsclassics
PostPosted: Sat Sep 20, 2025 8:11 am    Post subject: ignition and fuel distribution Reply with quote
Super nice kit, just I have to go with FIA regulations...distributor for ignition and fuel....;-(
Beartooth
PostPosted: Tue Sep 23, 2025 11:27 am    Post subject: Reply with quote
I've never found any good source for such schematics, and it may be the kind of thing Bosch and such companies kept to themselves. VW and Porsche (and other manufacturers) never publish that kind of thing because the expectation is always that the module will just be replaced. It could be out there, but it's the kind of thing I've learned to dig a bit on, but move on if I don't find it after a half hour or so of searching. The schematic would definitely help, but you can identify the simple electrical components individually, and there's a decent chance one or more of those is the problem. I was able to fix a speedometer head in my Mercedes that had an electrolytic capacitor fail (those are the culprit more often than not), which also took out a resistor. Sometimes the problem will show up visually; usually you can test the individual components, but that often requires removal anyway. So some people just replace everything. Finally, the integrated circuit may have failed too, in which case another module is your only choice. Luckily, mine's just worked, so I haven't touched it. There seems to be a reasonable supply of working used ones, so most people just try another if theirs goes - but it's always cool when you can fix something instead of just getting another.
1980 931 diamond in the rough
PostPosted: Tue Sep 23, 2025 9:03 pm    Post subject: Reply with quote
If you mean the box on the front fender of the S1 931 there should be at least one who knows the details . Silvio AKA Motanul here had a guy make a newly diy made plug in replacement that I had a look at last weekend, maybe he can add some details ?
