1 stud build
Goto page Previous  1, 2, 3 ... , 12, 13, 14  Next
PostPosted: Mon Apr 04, 2022 1:36 am    Post subject: Reply with quote
Juho wrote:
Reverse engineering intake flange was harder than i remember, this is going to take a lot of revisions
Right there with you especially when coming back to project you stopped for a while. You have to try and figure out what you were thinking back then. Its better to just follow through to the end rather than come back to a project unless you have better skills and/or tools. All my reverse engineering projects have revisions like crazy. Then people see them and think I just popped it out quickly. Ah no, some of them took me years I tell them. Turbo mount was one of those.
The best thing I have learned so far is studying my own work flow process and improving on that based on how things went in the past. Like looking back at a picture and realizing you are in a project for 7+ years and I am still working on it.
Juho
PostPosted: Mon Apr 04, 2022 2:16 am    Post subject: Reply with quote
Got my flange to match head perfectly now. I scrapped the one i did before and started working on a new one. took alot of tries, printing fitting and modyifying, now i can move to other parts.
Velocity stack adapter......
Still need to model curved velocity stack, im planning to do short manifold but long stacks
Juho
PostPosted: Mon Apr 04, 2022 8:24 pm    Post subject: Reply with quote
Very shorty bois now because less moment on the flange, have to make the stacks LONG and CURVED to clear hood, i think im going to go with these
Juho
PostPosted: Mon Apr 04, 2022 9:10 pm    Post subject: Reply with quote
Basic idea of the veloctity stack, someone tell me its shit so i have modify it.
Once im happy with the fitment i got to cfd it for silly mistakes
safe
PostPosted: Mon Apr 04, 2022 9:17 pm    Post subject: Reply with quote
A full radius gives a better flow. (like a solid donut on the end of the tube)
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
Juho
PostPosted: Mon Apr 04, 2022 9:28 pm    Post subject: Reply with quote
ty for the tip, went with this because easier to print
Changed it to donut design now
PostPosted: Tue Apr 05, 2022 1:13 am    Post subject: Reply with quote
You can design in some material under the full radii and it won't need any extra support, tried it on my flow bench stuff.
Juho
PostPosted: Tue Apr 12, 2022 2:12 am    Post subject: Reply with quote
Loom stuff came in
Juho
PostPosted: Tue Oct 31, 2023 5:35 pm    Post subject: Reply with quote
havent had any motivation for car for longtime but started now getting back to it
did very oversimplified cfd analysis on doing bends vs no bends on intake adapter
i studied preassure differences on different flow speeds and bend one seems to be bit better
also velocity stack adapter to cbrr itbs, need to still adjust tolerances but design is good enogh atm
Sweezer
PostPosted: Sat Nov 04, 2023 6:35 pm    Post subject: Reply with quote
Love your posts! Hang in there.
Juho
PostPosted: Tue Nov 14, 2023 4:53 am    Post subject: Reply with quote
Ive been naive to think that the 48mm cbr itbs would be the correct size for the 924. but ive finally come to senses after reading some stuff and switched to the other itbs i had. 38mm gsxr itbs. Nice thing with these is you can separate them resulting in straight runners, meaning less losses on intake adapter.
going to do minor changes on flange and fillets but its pretty much finished
i started on working on plenum. this is not finished it all, havent done any cfds or anything just made a model i can start playing with. Problem is atm there is so many variables that i can change so i need to narrow them down before starting cfd work. Currently reading on stuff to make better plenum...
im probaly gonna soon take the extra step of scanning engine bay to make sure everything fit and make a dummy model of the itbs itself.
Juho
PostPosted: Mon Apr 22, 2024 9:06 pm    Post subject: Reply with quote
Working on new cluster housing. houses stock speedo and 7inch screen. Going on third iteration now, first face was good but forgot that the dash has the supporting ridges so they didnt fit because of the screen, trying to slim down now
Juho
PostPosted: Fri May 24, 2024 3:37 pm    Post subject: Reply with quote
Designed and print enclosure for ecu and started wiring harness job by removing old wiring from the car.
Also added bosch oil preassue/temp sensor on stock location but im kind of paranoid to run it because its considerably longer than stock one. It threads on normally but could it be blocking oil flow? (Bosch 0261230482). Any of u had experience running this sensor?
PostPosted: Fri May 24, 2024 4:27 pm    Post subject: Reply with quote
This is pretty cool.
Juho
PostPosted: Sun Jun 02, 2024 3:06 am    Post subject: Reply with quote
due people asking here is intake flange. Its close enough
https://grabcad.com/library/porsche-924-intake-flange-1
Page 13 of 14
