mungodrums
Posted: Mon Mar 18, 2024 8:15 am Post subject: Found vacuum leak location, what is it? 88 924s |
| Today I smoked my 88 924s. Smoke comes out right under green plastic area. Is the AOS bottle vacuum hose leaking, hose section going into engine? Bottom of the hose which appears to connect to engine, plastic area. Is this causing vacuum leak, rough cold start, some idle hunting? Settle some when warmed up. Thinking of also replacing AOS rings, leaking slight oil on side of engine. Ger.[/img] |
