HELP NEEDED:PISTON REPLACEMENT
Goto page Previous  1, 2
R924T
PostPosted: Tue Oct 09, 2007 9:48 pm    Post subject: Reply with quote
I know the pistons have been used before, but never in a NA configuration? only turbo and supercharger. But there have been a lot of posting about it. Does someone know what kind of pistons the 924D engine used, im building an similar engine. Would be nice to met Racing some time, live in sweden too
simsport
PostPosted: Wed Oct 10, 2007 3:48 am    Post subject: Pistons Reply with quote
Ok, Im sold on these...can someone just confirm the code if I wanted to buy some. I wanted the number/description of these pistons. I know thay are VWType1, 87/88mm depending on current bore size but not sure of the correct item number with AA or is it also Bugpack?
Thanks a lot.
Simon
Blown is always best!
PostPosted: Wed Oct 10, 2007 8:53 am    Post subject: Reply with quote
these are the guys I got mine from, and a set of 88mm on their ebay store.
I also had them remove the cylinders to save weight on shipping,
The rings included were totally wrong though I think they were for a 90mm piston...
they are from a type 1 engine 88mm bore 69mm stroke
http://stores.ebay.com/kokoparts
http://cgi.ebay.com/ebaymotors/VW-88mm-1700cc-Aircool-Bug-Type-I-piston-cylinder-kit_W0QQcmdZViewItemQQcategoryZ34202QQihZ008QQitemZ180165084329
Leadfoot
Racing
PostPosted: Mon Oct 29, 2007 8:02 am    Post subject: Reply with quote
No offense,and for the sake of simplicity only guys.
R924;
E inget större problem.
Bor,å har verkstan min,i Göteborg.
Sen en tid tebax skojar jag ju mest med 16v cossie mercorna.
Nu e det iofs en stund sen jag spika i 931;orna,men om jag kan hjälpa dig så e det bara att säga till.Kikar om inte annat in här då å då.
Känner även gubbar som Sven å Utzon mfl..-för vad d e värt.
Om du vill ha tag i mig för att fråga ngt finns jag på 0737-189010 dagtid.
Jesper
Topls82
PostPosted: Sun Apr 23, 2023 5:02 am    Post subject: Pistons Reply with quote
Anyone have updated info on the flat head VW type pistons in 931 ?
Please share specs and mods needed
Frank
PostPosted: Tue May 23, 2023 1:36 am    Post subject: Reply with quote
These are the old pictures of the Utzon build which i am pretty sure are the VW units. Edit: I will say I am now highly interested in these too since I am no longer that interested in quench for a turbo build (which is a hard 180 for me). I am still digging if I have any more info
PostPosted: Tue May 23, 2023 2:45 am    Post subject: Reply with quote
Why would you skip the quench area ? our engines aren't exactly fast burners as it is?
PostPosted: Tue May 23, 2023 7:33 am    Post subject: Reply with quote
If I could do it close at around 1mm then I would do it but the quench pad could become very limited with all the porting and, in particular, the chamber work I have come across. If I would copy it to lessen the blow back on the long side radius flow of the port it seems like there isn't much pad area left. I have also seen the application of a radius from flat to chamber (Vizard). What is actually left and how affective will it be? I don't want to end up with lazy quench but that, supposedly, is only if you are actually applying quench with too large a gap (too thick of a gasket)
72rallye
PostPosted: Tue May 23, 2023 1:19 pm    Post subject: Euro NA pistons in 931 S2 Reply with quote
FWIW, I used a different route. Two of my 931 S2 pistons were cracked below the top piston ring. I didn't want to spend much money, and after some consideration bought a set of used Euro NA pistons.
The compression ratio of this combination calculates to 7.8:1, smack dab in the middle of the S1 and S2 engines. Since the bore is the same, one only needs to hone, but not machine the cylinders.
The engine runs fine with the new pistons, but I haven't had a chance to drive the car, yet. Also, until the WUR problems are sorted out it would be unsafe to use any boost.
I looked through the archives, but couldn't find any information on this setup. Maybe, because it's an obviously bad idea.
PostPosted: Wed May 24, 2023 1:30 am    Post subject: Re: Euro NA pistons in 931 S2 Reply with quote
That is an interesting way of approaching the problem. Not necessary a bad idea. Just an idea especially when funds are limited. Just keep us updated on how it runs
When safe runs an NA the way he does so successfully, we know these engines work, NA or Turbo
Page 2 of 2
