Does Xylene work to help pass smog?
mungodrums
PostPosted: Sun Nov 21, 2021 12:25 pm    Post subject: Does Xylene work to help pass smog? Reply with quote
I want to make sure the second time around that my 88 924s passes smog. Should I put in gallon of xylene along with 91 octane gas? How much gas should i put in along with 1 gallon of xylene? Im in Ca. Thx.
MikeDanger
PostPosted: Mon Nov 22, 2021 1:13 pm    Post subject: Reply with quote
no it wont, run as much pure alcohol as you can.
mungodrums
PostPosted: Mon Nov 22, 2021 2:44 pm    Post subject: Where do I find pure alcohol? Reply with quote
Where do I find pure alcohol? 99% alcohol, 100%? How much should I put in tank and also how much 91 octane gas? Ger.
safe
PostPosted: Mon Nov 22, 2021 7:57 pm    Post subject: Re: Where do I find pure alcohol? Reply with quote
E85 will work depending on what you are failing on, it will make the car run leaner and lower Co.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
