RancidLatte
Joined: 28 Aug 2018 Posts: 22 Location: Corpus Christi Texas
Posted: Thu Sep 30, 2021 5:56 pm Post subject: |
The links doesn't work, but I would guess the issue is in tie rods or ball joints or loose bearings (to much play). The bearings might be an adjustment issue. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
RancidLatte
Posted: Fri Oct 01, 2021 11:45 am Post subject: |
| safe wrote: | | The links doesn't work, but I would guess the issue is in tie rods or ball joints or loose bearings (to much play). The bearings might be an adjustment issue. |
I still don't know how to do links on this forum. I tried to have the image urls formatted in the way the forum suggests with [img] on either side. The links work for me when I click on them but maybe that is because I am the poster?
I looked up ball joints and that is exactly what appears to be damaged in my picture. _________________ 1987 Porsche 924s . Best First Car Ever |
anthonimartini
Joined: 17 Feb 2020 Posts: 240 Location: portland oregon
Posted: Fri Oct 01, 2021 12:01 pm Post subject: |
what wheels are you running? aftermarket wheels can cause stuff like this if they arent hub centric. or anything that can cause rapid toe changes to occur, check all your bushings and joints. _________________ ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password. |
